- Changed system requirements: Windows 7 and a processor with SSE2 instruction set. Windows XP is no longer supported.
 - Default output mode is now WASAPI shared.
 - New fading capability that works with alternate output modes.
 - Default archive reader now supports 7-zip format.
 - Added support for WebP album covers (Default UI, Properties dialog). Settings need to be changed to look for folder.webp instead of folder.jpg.
 - Removed mixer volume sync feature due to bugs.
 - Cleaned up foo_rgscan alter-file-content & alter-opus-header methods.
 - Removed obsolete edit-replaygain-info menu command since Properties dialog does the same now.
 - Added an option to disregard mouse back/forward buttons (by default mapped to previous/next track).
 - Double clicking a line in Properties album art tab now opens a fullsize image viewer.
 - Fileops & Converter: Added alternate handling of invalid filename characters, toggled in Advanced Preferences.
 - Freedb component updated: now queries all configured servers and displays results grouped by server.
 - Updated File Operations & Converter file name pattern picker dialog, now auto selects current pattern on open if possible.
 - CDDA reading no longer requires admin privileges on Windows Server.
 - Updated autoplaylist editing dialogs, made resizable.
 - Standard DSP Array is no longer an optional component, as it's required for new WASAPI output to work correctly.
 - Converter: Added a toggle for encoding thru temp folder to custom command-line encoder setup, required for some encoders that don't support Unicode.
 - Added alternate menu commands for opening Properties dialog with specific tab open, for mapping keyboard shortcuts only.
 - Improved recovery from unplugged audio output device.
 - Additional editable Properties ReplayGain tab summary fields.
 - Fixed crash when trying to alter gain on a Matroska file with no recognized audio track.
 - Fixed incorrect handling of folder/file.ext relative paths in playlists served over HTTP/HTTPS/FTP.
 - New portable install puts all configuration data in 'profile' subfolder of install folder instead of saving in the installation folder directly. Doesn't affect upgraded installs or non-portable.
 - Fixed 'remove tags' not correctly stripping tags from raw AAC files.
 - Fixed ZIP reader memory leak.
 - Improved handling of last modification times in ZIP and RAR archives.
 - Fixed a bug causing high CPU usage with autoplaylists that are force-sorted but with no pattern specified.
 - Fixed installer incorrectly labelling some components as incompatible, if they have been installed by copying DLLs manually.
 - Fixed incorrect handling of ID3 itunescompilation=0.
 - Fixed a bug causing files with very long names inside ZIP archives to be unplayable.
 ). И ещё, вот поэтому -
