foobar2000 v1.6.0
Сообщение #1 VEG » 30.06.2020, 14:07
Вышла финальная версия foobar2000 v1.6.0! Предыдущая версия: foobar2000 v1.5.5.
  • Changed system requirements: Windows 7 and a processor with SSE2 instruction set. Windows XP is no longer supported.
  • Default output mode is now WASAPI shared.
  • New fading capability that works with alternate output modes.
  • Default archive reader now supports 7-zip format.
  • Added support for WebP album covers (Default UI, Properties dialog). Settings need to be changed to look for folder.webp instead of folder.jpg.
  • Removed mixer volume sync feature due to bugs.
  • Cleaned up foo_rgscan alter-file-content & alter-opus-header methods.
  • Removed obsolete edit-replaygain-info menu command since Properties dialog does the same now.
  • Added an option to disregard mouse back/forward buttons (by default mapped to previous/next track).
  • Double clicking a line in Properties album art tab now opens a fullsize image viewer.
  • Fileops & Converter: Added alternate handling of invalid filename characters, toggled in Advanced Preferences.
  • Freedb component updated: now queries all configured servers and displays results grouped by server.
  • Updated File Operations & Converter file name pattern picker dialog, now auto selects current pattern on open if possible.
  • CDDA reading no longer requires admin privileges on Windows Server.
  • Updated autoplaylist editing dialogs, made resizable.
  • Standard DSP Array is no longer an optional component, as it's required for new WASAPI output to work correctly.
  • Converter: Added a toggle for encoding thru temp folder to custom command-line encoder setup, required for some encoders that don't support Unicode.
  • Added alternate menu commands for opening Properties dialog with specific tab open, for mapping keyboard shortcuts only.
  • Improved recovery from unplugged audio output device.
  • Additional editable Properties ReplayGain tab summary fields.
  • Fixed crash when trying to alter gain on a Matroska file with no recognized audio track.
  • Fixed incorrect handling of folder/file.ext relative paths in playlists served over HTTP/HTTPS/FTP.
  • New portable install puts all configuration data in 'profile' subfolder of install folder instead of saving in the installation folder directly. Doesn't affect upgraded installs or non-portable.
  • Fixed 'remove tags' not correctly stripping tags from raw AAC files.
  • Fixed ZIP reader memory leak.
  • Improved handling of last modification times in ZIP and RAR archives.
  • Fixed a bug causing high CPU usage with autoplaylists that are force-sorted but with no pattern specified.
  • Fixed installer incorrectly labelling some components as incompatible, if they have been installed by copying DLLs manually.
  • Fixed incorrect handling of ID3 itunescompilation=0.
  • Fixed a bug causing files with very long names inside ZIP archives to be unplayable.
VEG M Онлайн
Автор темы, Администратор
С нами: 14 лет 4 месяца
Сообщение #81 Azaza » 21.08.2020, 19:09
iPhoneSasuke:Надо как-то Питеру сообщить
iPhoneSasuke:Я из любопытства на beta 2 сижу. Новые беты постоянно выпускаются и когда читаешь их логи, кажется: «О, ужас!». Поэтому жду релиза.
А потом будете удивляться, почему баги и проблемы оказались и в финальной версии?
С нами: 10 лет
Сообщение #82 NikosColev » 22.08.2020, 03:52
VEG:Default output mode is now WASAPI shared.
Сегодня заметил, что при его использовании трек 192 кГц приходит на ресивер по HDMI 44.1 кГц, в отличии от WASAPI.
Это баг или настраиваемая фича?
NikosColev
Сообщение #83 VEG » 22.08.2020, 11:06
WASAPI бывает Shared (это обычный режим) и Exclusive. Раньше видимо у вас был Exclusive, сейчас Shared. При Shared звук сводится с той частотой дискретизации и разрядностью, что указаны в настройках аудиовыхода в Windows. Можете поменять там.
VEG M Онлайн
Сообщение #84 NikosColev » 22.08.2020, 12:19
VEG:При Shared звук сводится с той частотой дискретизации и разрядностью, что указаны в настройках аудиовыхода в Windows. Можете поменять там.
Спасибо, не знал. Где-то прочитал, что при использовании WASAPI эти параметры влияют только на "фоновый шум, чем меньше - тем лучше", так и стоят в дефолте.
NikosColev
Сообщение #85 Azaza » 22.08.2020, 13:33
NikosColev:Где-то прочитал, что при использовании WASAPI эти параметры влияют только на "фоновый шум, чем меньше - тем лучше", так и стоят в дефолте.
Вы "где-то" прочитали очередную лажу. При WASAPI Exclusive эти параметры ни на что не влияют, а
С нами: 10 лет
Сообщение #86 NikosColev » 22.08.2020, 13:36
Azaza, я в этом убедился сразу после первого ответа)))
NikosColev
Сообщение #87 iPhoneSasuke » 25.08.2020, 10:03
iPhoneSasuke:именно в 1.6 столкнулся с затыками при перемотки треков, которые возникают рандомно.
VlaKor:Это которое:
"Changes in beta 5
Fixed incorrect behavior when repeatedly hitting prev/next with fading enabled." ?
Проверил beta 14. Словил затык на первом же треке.
Откатился до 1.5.1 и нет никаких затыков, и мотается как-то точнее и нежнее.
Доволен :pray:
Изучение логов, начиная с 1.5.5 меня наводило на мысли, что число новых багов таки перевешивало количество исправлений/улучшений.
iPhoneSasuke M
С нами: 11 лет 8 месяцев
Сообщение #88 VlaKor » 25.08.2020, 21:39
iPhoneSasuke:Проверил beta 14. Словил затык на первом же треке.
Отправьте репорт Пете, сделаете полезное дело.
А я наверно как то не так пользуюсь Foobar2000. Всё время обновляюсь на последнюю бету или релиз и не одного бага, хоть бы раз.
VlaKor
С нами: 9 лет
Сообщение #89 Azaza » 26.08.2020, 18:03
iPhoneSasuke, каков точный сценарий, при котором можно обнаружить затыки: DSP, настройки вывода, формат файла? Проявляется ли на чистой установке?
С нами: 10 лет
Сообщение #90 iPhoneSasuke » 26.08.2020, 19:33
Azaza:каков точный сценарий, при котором можно обнаружить затыки: DSP, настройки вывода, формат файла? Проявляется ли на чистой установке?
От формата файла не зависит: у меня всё FLAC'и, разрядность от 44.1/16 до 48/24. Проявляется на любом из них. Когда мотаю песню туда-сюда. Логики в возникновении нет, очень рандомно, и не слишком часто, но за день точно раза три бывало.
В DSP только ресемплер SoX, и то даже без него затыки были.
Вывод в Wasapi Shared, оптика через ZxR на ЦАП.
Стоковый фубар не юзал никогда. Могу скинуть просто 2 билда: беспроблемный 1.5.1 и проблемный 1.6.0.
iPhoneSasuke M
Сообщение #91 Azaza » 26.08.2020, 19:56
Ну давайте проблемный.
С нами: 10 лет
Сообщение #92 iPhoneSasuke » 26.08.2020, 20:05
Azaza:Ну давайте проблемный.
https://yadi.sk/d/P6m8t--IArXHAg
iPhoneSasuke M
Сообщение #93 vladj » 26.08.2020, 22:17
В Preferences >Advanced > Playback >WASAPI почему-то не установлена галочка на высокий приоритет процесса, но и без этого сколько нужно бага ждать ибо всё нормально работает ? Выводил на цап по коксу стерео 24/96000, 24/192000 и прочие. Сборка изуродована, выкинуты панели плейлистов и библиотека. Ну да ладно...хозяин-барин :smile:
Сообщение #94 iPhoneSasuke » 26.08.2020, 23:13
vladj:выкинуты панели плейлистов и библиотека
Я это целенаправленно выпиливал)) Под корню. Потому что реализация страшная. Что в оригинале, что в прочих авторских сборках. Какой смысл в библиотеках, когда они утрамбовываются в частичку небольшого окошка плеера? Проще через Проводник рыскать... Плейлист тоже не моя тема, т.к. они приедаются. В итоге убрал всё лишнее и оставил только нужное.
vladj:сколько нужно бага ждать
Как писал выше — в бета 14 словил при первом же запуске трека.
Надеюсь, понятно, что речь не про прослушивание и не про перелистывание с трека на трек, а перемотку в рамках одного трека.
iPhoneSasuke M
Сообщение #95 vladj » 27.08.2020, 12:49
Скачивал по вчерашней ссылке, в настройках не рыл ничего, перемотку тестил на всяких форматах, мало того даже на треке длиной 40 минут, Sample rate : 96000 Hz / Bits per sample : 24 / Bitrate : 2951 kbps / File size : 811 MB. При поиске сикбаром переход по треку практически мгновенный в любую сторону, любое количество раз, на любую отметку. Треки на винте полторашке, (зелёный WD, низкооборотистый). Выход по wasapi, буфер 50 ms.
Сообщение #96 Azaza » 27.08.2020, 18:40
Я тоже мотал, мотал, но так и случилось никаких затыков. Может, это на десятке только. А в консоли при этих затыках ничего не пишется?
С нами: 10 лет
Сообщение #97 iPhoneSasuke » 27.08.2020, 19:48
Azaza:А в консоли
Какой? Нигде ничего не вылетает.
iPhoneSasuke M
Сообщение #98 Azaza » 27.08.2020, 20:04
Той, которая обычно вызывается через View->Console. А в сборке я не нашёл способа её вызвать, кроме как через горячие клавиши, которые нужно сначала задать в настройках горячих клавиш.
К слову, Peter сейчас снова исправляет баги, связанные с выводом. Так что будет иметь смысл потестить бету 17, когда она выйдет, уже вышла.
С нами: 10 лет
Сообщение #99 vladj » 27.08.2020, 20:20
Azaza:Может, это на десятке только
На двух флешках есть ремонтные десятки, там тоже всё нормально. Естественно я не инсталлирую на них фубар, он у меня без исключения только портабельный (сборок 30-40), просто гружусь в ремонтную вин 10 и в ней запускаю любой фубар. Замечу, что везде и на винде и в линукс никогда не пользуюсь свопом хотя линукс им не злоупотребляет, а вот винда любит посбрасывать-забрать что-то оттуда даже при наличии нормального объёма оперативы.
Сообщение #100 iPhoneSasuke » 29.08.2020, 12:35
Azaza:Peter сейчас снова исправляет баги, связанные с выводом
Устраняет то, чего многие не замечали, или то, что завезено в 1.6.0?
iPhoneSasuke M
