foobar2000 v1.6.0
Сообщение #1 VEG » 30.06.2020, 14:07
Вышла финальная версия foobar2000 v1.6.0! Предыдущая версия: foobar2000 v1.5.5.
  • Changed system requirements: Windows 7 and a processor with SSE2 instruction set. Windows XP is no longer supported.
  • Default output mode is now WASAPI shared.
  • New fading capability that works with alternate output modes.
  • Default archive reader now supports 7-zip format.
  • Added support for WebP album covers (Default UI, Properties dialog). Settings need to be changed to look for folder.webp instead of folder.jpg.
  • Removed mixer volume sync feature due to bugs.
  • Cleaned up foo_rgscan alter-file-content & alter-opus-header methods.
  • Removed obsolete edit-replaygain-info menu command since Properties dialog does the same now.
  • Added an option to disregard mouse back/forward buttons (by default mapped to previous/next track).
  • Double clicking a line in Properties album art tab now opens a fullsize image viewer.
  • Fileops & Converter: Added alternate handling of invalid filename characters, toggled in Advanced Preferences.
  • Freedb component updated: now queries all configured servers and displays results grouped by server.
  • Updated File Operations & Converter file name pattern picker dialog, now auto selects current pattern on open if possible.
  • CDDA reading no longer requires admin privileges on Windows Server.
  • Updated autoplaylist editing dialogs, made resizable.
  • Standard DSP Array is no longer an optional component, as it's required for new WASAPI output to work correctly.
  • Converter: Added a toggle for encoding thru temp folder to custom command-line encoder setup, required for some encoders that don't support Unicode.
  • Added alternate menu commands for opening Properties dialog with specific tab open, for mapping keyboard shortcuts only.
  • Improved recovery from unplugged audio output device.
  • Additional editable Properties ReplayGain tab summary fields.
  • Fixed crash when trying to alter gain on a Matroska file with no recognized audio track.
  • Fixed incorrect handling of folder/file.ext relative paths in playlists served over HTTP/HTTPS/FTP.
  • New portable install puts all configuration data in 'profile' subfolder of install folder instead of saving in the installation folder directly. Doesn't affect upgraded installs or non-portable.
  • Fixed 'remove tags' not correctly stripping tags from raw AAC files.
  • Fixed ZIP reader memory leak.
  • Improved handling of last modification times in ZIP and RAR archives.
  • Fixed a bug causing high CPU usage with autoplaylists that are force-sorted but with no pattern specified.
  • Fixed installer incorrectly labelling some components as incompatible, if they have been installed by copying DLLs manually.
  • Fixed incorrect handling of ID3 itunescompilation=0.
  • Fixed a bug causing files with very long names inside ZIP archives to be unplayable.
Автор темы, Администратор
С нами: 13 лет 10 месяцев
Сообщение #101 Azaza » 29.08.2020, 15:04
То, что в 1.6 появилось.
С нами: 9 лет 6 месяцев
Сообщение #102 iPhoneSasuke » 01.09.2020, 11:28
Changes in beta 18
Fixed a long time bug causing files with very long names inside ZIP archives to be unplayable.
Internal changes in resampler management
Ох уж эти нововведения...
iPhoneSasuke M
С нами: 11 лет 2 месяца
Сообщение #103 maniac736 » 04.09.2020, 09:30
Судя по всему у версии 1.6.0 есть проблемы с Panel Stack Splitter. Кто-нибудь сталкивался?
maniac736 M
С нами: 8 лет 5 месяцев
Сообщение #104 NikosColev » 04.09.2020, 21:40
maniac736:у версии 1.6.0 есть проблемы с Panel Stack Splitter. Кто-нибудь сталкивался?
Подскажите какой развивающийся плагин имеет схожую функциональность с Panel Stack Splitter?
Разобрался, спс.
NikosColev
Сообщение #105 maniac736 » 06.09.2020, 15:41
Попробовал заапгрейдить до данной версии свою относительно простенькую сборку и разочаровался. Пока остался на 1.5.5 :sad:
maniac736 M
Сообщение #106 VlaKor » 06.09.2020, 18:37
maniac736:Попробовал заапгрейдить до данной версии свою относительно простенькую сборку и разочаровался. Пока остался на 1.5.5 :sad:
Чем? Если не секрет ))
VlaKor
Сообщение #107 maniac736 » 07.09.2020, 11:25
VlaKor, не хотелось отказываться от плагинов UI Hacks + Panel Stack Splitter
maniac736 M
Сообщение #108 MeinHerz » 07.09.2020, 18:50
Личная позиция по предпочтению новых версий потерпела жестокое поражение. Откатился на 1.4.6 и почувствовал себя настолько спокойно, как в животе матери (а вы это помните? Я помню.).
MeinHerz
С нами: 7 лет 10 месяцев
Сообщение #109 SergPuh.68 » 07.09.2020, 19:00
Дальше версии 1.5.5. не пойду,как я понял там неизвестность :biggrin:
С нами: 7 лет 2 месяца
Сообщение #110 AHAPXICT » 08.09.2020, 22:04
SergPuh.68:Дальше версии 1.5.5. не пойду,
SergPuh.68, без шуток, или что я пропустил в версии 1.5.6 final ? Я поставил, вернее заменил старую 1.5.5 на 1.5.6 вроде всё работает. Если честно, то даже перед установкой лог не читал.
С нами: 12 лет 4 месяца
Сообщение #111 SergPuh.68 » 08.09.2020, 23:22
AHAPXICT, пока не понятно.Для меня особой разницы между 1.5.5 и 1.5.6 нет.При прослушивании музыки с компа вообще никаких проблем не возникает.Просто сейчас пытаюсь прикрутить к фубару просмотр плейлистов с IPTV каналами и просмотр фильмов с HD кинотеатров,и тут становится не понятно толи дело в плохой идее толи в версии плеера,всё работает но как то со скрипом.В версии 1.6 наверное всё бы получилось но её использование по известным причинам для меня не приемлемо,увы.
Сообщение #112 AHAPXICT » 09.09.2020, 00:39
SergPuh.68, ну тогда всё нормально. А я подумал что в 1.5.6 есть какой-то косяк, ну да ладно. Спасибо за уточнение.
Сообщение #113 Aum » 23.09.2020, 18:46
postED:Берите исходники foo_ui_hacks у DRON'а
А я б чеканной монетой поддержал)) Хороший компонент, развязывает руки при создании сборки своей мечты: возможность отключить рамки винды и прикрутить различные assemblies в меню portable. И в новой версии плеера как раз это все сломалось((
Aum M
Вернуться в Новости плеера
