- Added support for HLS: HTTP Live Streaming. To use, add internet M3U8 file through Add Location dialog.
- Enabled icy-metadata support for Ogg FLAC internet radio streams.
- Updated Properties / ReplayGain page layout if editing a single file.
- Improved Properties dialog performance, list of autocomplete entries is populated asynchronously.
- Enabled embedded album art loading from raw .AAC files with ID3 tags.
- Updated FFmpeg to 4.3.1.
- Added support for playing Matroska A_MS/ACM content.
- Fixes for rare AAC codec configurations that FFmpeg doesn't fully support - an add-on decoder can override the built-in one for such special cases.
- Decoders are now made aware of output sample rate (from Windows Mixer settings) and can decode certain formats directly to the intended sample rate, skipping potential resampling steps.
- Fixed "fade on manual track change" setting not being used since version 1.6. (beta 6)
- Changing volume no longer affects Windows Mixer sliders; restarting foobar2000 no longer resets Windows Mixer slider to 100%. (beta 7)
- Mitigated crash when initiating drag&drop of a very large number of songs (such as Album List "all music"). (beta 8)
- Enabled support for 7-zip archives using PPMd compression. (beta 8)
