- Support for modern processor architectures. Now available as:
- x86 32-bit (legacy) - requires Windows 7 or newer.
 - x86 64-bit - requires Windows 7 64-bit or newer.
64-bit foobar2000 requires 64-bit builds of components; it can not load legacy 32-bit components. However, at this time, most components have 64-bit builds available already. - ARM - requires Windows 11 ARM device.
 - User interface updates:
- Dark mode support on Windows 10 and 11. Add-on components need to be updated to utilize it.
 - Added album art in Default User Interface playlist view.
 - Clickable rating stars in Default User Interface playlist view (with new Playback Statistics component only).
 - New Default UI element: ReFacets, reimplementing most of Facets functionality. Old Facets component doesn't work with new 64-bit foobar2000.
 - Improved Default UI splitter, now allows any number of panes.
 - Added 'remember per playlist layout' to Default User Interface playlist view.
 - Added 'stream selector' element to Default User Interface toolbar.
 - Some Default UI Elements (ReFacets, Equalizer, visualisations) now also accessible as Columns UI panels.
 - Made more edit boxes recognize ctrl+backspace.
 - Fixed remembered main window position/size not respecting system DPI settings.
 - Configuration management changes:
- New internal playlist format, changes instantly saved to disk, no more recent changes lost on crash.
 - New configuration data format, changes instantly saved to disk, no more recent changes lost on crash.
 - For non-portable installs, profile folder is now %appdata%\foobar2000-v2. There is no need to back up old profile before upgrading, your foobar2000 v1.x profile will be left untouched.
 - First run performs import of old configuration data (playlists, library).
 - New full config reset semantics - now clears profile folder (optionally leaving user-components intact) instead of asking all components to reset themselves.
 - DSP technology updates:
- Made possible to apply DSP config changes without reinitializing affected DSPs.
 - Allowed DSPs to manipulate their shown name depending on preset data.
 - Added crossfeed DSP from foobar2000 mobile.
 - Added sample rate exclusions to SSRC resampler.
 - Audio codec technology updates:
- More audio formats supported out of the box: TAK, APE, AC3, DTS.
 - Latest revision of APE format is supported (Monkey's Audio 10.09).
 - Updated WavPack to version 5.6.0.
 - Updated FFmpeg to version 6.0.
 - libvorbis is now used for decoding Vorbis format instead of FFmpeg, as some rare files continue to cause compatibility issues.
 - Cleaned up Ogg reader, made possible to seek in remote (HTTP etc) Ogg files.
 - Made FLAC tag updater remove ID3v2 garbage prefixing FLAC stream.
 - Made MP3 reader report MP3 frame count not matching Xing/LAME header info when verifying integrity.
 - Fixed bad MD5 verification of AIFF sourced WavPacks.
 - Added extra sanity checks to tag update operations in built-in codecs: made sure that attempts to remove covers from files that didn't have them in first place don't alter files at all.
 - Properties dialog updates:
- Properties dialog now follows theme colors of the active UI.
 - Improved behavior if 'reload info' detects a change in number of chapters etc.
 - Updated Automatically Fill Values logic, better results if searched pattern appears more than once.
 - Logs tag update errors to console.
 - These add-on components are now obsolete as their functionality is available out of the box:
- foo_benchmark
 - foo_bitcompare
 - foo_verifier
 - foo_input_monkey
 - foo_ac3
 - foo_sanitizer
 - foo_input_dts
 - These components previously included with the installer are no longer optional (features always enabled):
- foo_rgscan
 - foo_cdda
 - foo_albumlist
 - Other:
- Media Library efficiency improvements for very large music libraries.
 - New audio output device management features - unwanted devices can be disabled, bit depth and DSP can be configured per-device.
 - Can display file creation time (%file_created%) and attributes (%file_attributes%).
 - Internet Radio dialog (File menu), remembers previously played Internet radio streams.
 - Modernized Explorer integration, no longer needs separate 32bit/64bit shell extension DLLs.
 - Utilized Windows Imaging Component for picture decoding, removed libwebp dependency. Album covers in HEIF, AVIF, etc can now be viewed if system codecs are present.
 - Added %year% mapping, takes year part of %date%, discarding content past first four digits.
 - Changed default Album List patterns to use %year%.
 - New console logging system, writes per-instance log files to the specified folder.
 - Fixed incorrect handling of M4A itunescompilation=0.
 - Fixed glitching when seeking with smooth playback and CPU-heavy DSPs active.
 - Converter: Pass float32 audio to LAME encoder.
 - Changed replacement for slash character in file naming.
 - Fixed audio glitching on screen resolution change in certain configurations.
 - Improved exclusive output behavior with uncommon channel layouts, 4.1/5.0 would not play on a device expecting 5.1-side.
 - Worked around ages old problem with external changes to file tags causing loss of foo_playcount data (needs new foo_playcount).
 - Preferences / Shell: changed default target playlist name.
 - Better console logging of internet radio stream reconnect events.
 - Worked around foo_input_dvda bugs, no longer crashes on null album art data returned.
 - Updated exclusive output device-specific workarounds.
 - Compiled with Visual Studio 2022.
