  • 21
Скриншоты
Примечания
Album list panel
ASIO support
Channel Spectrum panel
Columns UI
CUE fixer
Discogger
DR Meter
DSD Processor
DVD-Audio Decoder
ELPlaylist
EsPlaylist
Explorer Tree
HDCD decoder
Lyric Show Panel
Masstagger
MIDI Player
Multi-source lyrics
Panel Stack Splitter
Playback Statistics
Pretty Popup
Quick Search Toolbar
Run services
Skip Track
Spider Monkey Panel
Stop After Queue
Super Audio CD Decoder
Text Tools
vgmstream plugin
VST 2.4 adapter
VU Meter
Waveform seekbar
Дата сборки: 30.01.2026
Модифицировал: kutuzof
Версия плеера: 2.25.6 [x86]
История изменений: 30.01.2026
Старые версии плеера
Скриншоты
Версия сборки "DarkOne v4.0" от AHAPXICT [оригинальный автор - tedGo] | 30.01.2026
Последний раз редактировалось kutuzof 30.01.2026, 11:52, всего редактировалось 340 раз(а).
Сообщение #501 Jacob » 13.06.2023, 00:18
Hello, Kutuzoff.
Once you have unpacked "DarkOne4Mod v1.0 (SMP) - fb2k v2.0 [x86].exe" in a folder other than "C:\Portable\DarkOne4Mod v1.0 '('SMP')'\foobar2000 \", is there a way, a tool to automatically replace all occurrences of "C:\Portable\DarkOne4Mod v1.0 '('SMP')'\foobar2000\" with the desired path ?
The path "C:\Portable\DarkOne4Mod v1.0 '('SMP')'\foobar2000\" is notably written in the pmf files of "foobar2000 v2.0 DarkOne4Mod\themes\DarkOne4Mod\Others\Peakmeter Spectrum\pmf\" and in "Preferences\Display\Album art\Front cover"
Jacob
С нами: 2 года 10 месяцев
Сообщение #502 Jacob » 17.06.2023, 20:04
Solution considered to avoid having to modify certain foobar files:
FreeMove
https://github.com/imDema/FreeMove
Move directories freely without breaking installations or shortcuts.
You can use this tool to move programs that install on C:\ by default to another drive to save space on your main drive
1.The files are moved to the new location
2.A symbolic link is created from the old location redirecting to the new one. Any program trying to access a file in the old location will automatically be redirected to its new location
Jacob
Сообщение #503 pinyuszka » 31.07.2023, 00:04
Hi Kutuzof!
On the biography interface, how can I set it so that it does not save the photos?
Many images accumulate in the foobar2000/yttm/art_img folder.
pinyuszka
С нами: 4 года
Сообщение #504 kutuzof » 31.07.2023, 20:54
pinyuszka, есть настройка, но если в пути к плееру есть скобки, то она не будет работать (ошибка "Biography"). Для этого лучше использовать версию 1.5.11.
Сообщение #505 pinyuszka » 01.08.2023, 21:31
I looked for the Biography setting referring to this, but I couldn't find it, it was well hidden ;) Thanks for the useful information!
pinyuszka
С нами: 4 года
Сообщение #506 Jet34 » 05.08.2023, 23:24
Как настроить экран панели vu meter, он получается вытянутый по вертикали, до этого был нормальный, но переустановил foobar и вот не какие настройки из мной пробуемых не помогли..
Jet34
С нами: 2 года 5 месяцев
Сообщение #507 Alktar » 25.08.2023, 21:15
При обновлении роутера полностью слетела библиотека ( львиная доля библиотеки на дисках внешних), опять по новой все загружается. Можно как то библиотеки список сохранять в файл, чтобы при таких случаях восстанавливать? Ведь осстанавливаться она будет так долго.
Alktar
С нами: 2 года 11 месяцев
Сообщение #508 VEG » 25.08.2023, 23:37
foo_jesus умеет периодически делать бэкапы всего указанного в папке с фубаром. Из таких бэкапов что угодно можно восстановить.
Сообщение #509 first.piano1 » 27.08.2023, 22:59
Отличная сборка
А "дополнительные индикаторы к "foo_vis_vumeter" в какую папку кидать?
first.piano1
С нами: 5 лет 6 месяцев
Сообщение #510 kutuzof » 28.08.2023, 06:39
first.piano1, в любую, либо в саму папку компонента, либо создайте ещё одну папку.
Сообщение #511 first.piano1 » 31.08.2023, 21:22
kutuzof:first.piano1, в любую, либо в саму папку компонента, либо создайте ещё одну папку.
Нет, я немного не про это.
Как сделать так, чтобы фубар видел новые добавленные индикаторы, которые я положу в новую папку?
first.piano1
Сообщение #512 kutuzof » 31.08.2023, 21:55
ПКМ --> Group --> выбрать нужную папку
Сообщение #513 first.piano1 » 03.09.2023, 21:21
А кнопки Play\Pause с подсветкой можно сделать, как в сборке у анархиста?
first.piano1
Сообщение #514 first.piano1 » 07.09.2023, 19:38
Еще не пойму одной вещи - нажимаю на стоп, трек останавливается, и сбрасывается на начало.
То есть, при следующем запуске песня начинается с начала...
Как это пофиксить? :insane:
first.piano1
Сообщение #515 kutuzof » 08.09.2023, 09:31
first.piano1:трек останавливается, и сбрасывается на начало.
это стандартное поведение любого плеера ) нет? Для этого ведь есть "Pause". А что бы запоминало при выходе из фубара поставьте галочку (см. скриншот)
first.piano1:кнопки Play\Pause с подсветкой можно сделать
цветные кнопки уже есть (кликайте средней кнопкой на самих кнопках воспроизведением).
Сообщение #516 first.piano1 » 11.09.2023, 23:17
kutuzof, все отлично, спасибо!
first.piano1
Сообщение #517 BioMax » 13.09.2023, 11:07
в ВАЖНО указано что менять папку назначения нельзя...то есть я не смогу установить сборку на другой диск или после распаковки все же можно перенести все куда мне нужно?
BioMax
С нами: 2 года 4 месяца
Сообщение #518 petrov71_71 » 25.09.2023, 21:25
Здравствуйте! У меня к Вам такая просьба...Я любитель винила и много таких отцифровок нельзя сделать чтобы отображалась обложка второй стороны диска Типа Disc 2 или Disc B что то в этом роде. Если это возможно подскажите как? Сборка DarkOne4Mod v1.0 (SMP) - fb2k v2.0 [x86]
petrov71_71
С нами: 3 года 1 месяц
Сообщение #519 kutuzof » 26.09.2023, 07:58
petrov71_71:чтобы отображалась обложка второй стороны диска Типа Disc 2 или Disc B
Где отображалась? И где у вас лежат обложки (их название)? поконкретней:)
BioMax:или после распаковки все же можно перенести все куда мне нужно?
Нет :hi:
Сообщение #520 petrov71_71 » 26.09.2023, 11:31
Чтобы Disc 2 отображался как на фото. Файлы лежат в папке Cover в альбме где и расположены аудио файлы. Название файлов Front cover/Back cover/Disc/Disc2(на некоторых Disc B)
petrov71_71
