  • 21
Скриншоты
Примечания
Album list panel
ASIO support
Channel Spectrum panel
Columns UI
CUE fixer
Discogger
DR Meter
DSD Processor
DVD-Audio Decoder
ELPlaylist
EsPlaylist
Explorer Tree
HDCD decoder
Lyric Show Panel
Masstagger
MIDI Player
Multi-source lyrics
Panel Stack Splitter
Playback Statistics
Pretty Popup
Quick Search Toolbar
Run services
Skip Track
Spider Monkey Panel
Stop After Queue
Super Audio CD Decoder
Text Tools
vgmstream plugin
VST 2.4 adapter
VU Meter
Waveform seekbar
Дата сборки: 23.01.2026
Модифицировал: kutuzof
Версия плеера: 2.25.6 [x86]
История изменений: 23.01.2026
Старые версии плеера
Скриншоты
Версия сборки "DarkOne v4.0" от AHAPXICT [оригинальный автор - tedGo] | 23.01.2026
Последний раз редактировалось kutuzof 24.01.2026, 16:00, всего редактировалось 339 раз(а).
Сообщение #541 kutuzof » 10.12.2023, 09:35
gajdar79:is it possible to turn off biography downloads for radio stations?
https://foobar2000.ru/forum/viewtopic.php?p=83905#p83905
Сообщение #542 gajdar79 » 14.12.2023, 22:30
kutuzof, Hi, thank you very much for your help, I have one more question.... Why can't I enlarge the font for album list and ELPlaylist? When I enter any size, the font stays the same, only the font style can be changed.
gajdar79
С нами: 2 года 2 месяца
Сообщение #543 kutuzof » 15.12.2023, 12:22
gajdar79:Why can't I enlarge the font for album list and ELPlaylist? When I enter any size, the font stays the same, only the font style can be changed.
This is due to the incompatibility of two components "foo_ui_columns" and "foo_ui_hacks". But this can be circumvented by temporarily disabling the "foo_ui_hacks" component. Rename the component folder "foo_ui_hacks" to "_foo_ui_hacks", change the font size to the desired size, then change the folder name back to "foo_ui_hacks".
And for "ELPlaylist", just right-click, then "Group by" and select the desired row height.
Сообщение #544 gajdar79 » 16.12.2023, 02:03
kutuzof:Rename the component folder "foo_ui_hacks" to "_foo_ui_hacks", change the font size to the desired size, then change the folder name back to "foo_ui_hacks".
Thanks, I wouldn't have figured that out.
gajdar79
Сообщение #545 gajdar79 » 17.12.2023, 21:25
Hello, Kutuzoff
Can I change the font color under the cover?
gajdar79
Сообщение #546 kutuzof » 17.12.2023, 22:29
Yes, sure...
Сообщение #547 boytronic » 18.12.2023, 20:48
kutuzof добрый вечер, ну тогда и я спрошу про изменение цвета, можно ли изменить цвет у индикатора, когда пики переваливают за 0дб ?
boytronic
Сообщение #548 kutuzof » 18.12.2023, 21:19
boytronic, вот ссылка на исходники (сам переделывать не буду).
https://drive.google.com/file/d/1w7WtyOzA5s4OPlMtnWesEidFOnTEtIoB/view?usp=drive_link
Сообщение #549 boytronic » 19.12.2023, 12:32
boytronic
Сообщение #550 kutuzof » 20.12.2023, 20:31
История изменений: 20.12.2023
1. Обновлено:
- foobar2000 v2.1 [x86]
- foobar2000 v1.6.17
- Free Encoder Pack 2023-07-05
- компоненты
- плейлисты (RADIO DIGITAL IMPULSE удалён - больше не работает)
2. Добавлено:
- 467 пресетов для MilkDrop (папка 2077) от автора @serge000 [https://github.com/milkdrop2077/MilkDrop3/]
- источник информации "Nowplaying" в панели биографий [файл для редактирования - "nowplaying.txt"]
- кнопка "Copy name(s)" - СКМ на кнопке "Delete"
- кнопка (меню) "Run service" - СКМ на кнопке "Convert"
- кнопка (меню) "Radio" - СКМ на кнопке "Discogs" (кнопка "Like" перенесена на кнопку "Mute")
- предустановки для "Peakmeter Spectrum Visualisation" (старые доработаны)
3. Изменено:
- Cover Panel #1 теперь тоже отображает логотипы радио (вкл/выкл - через меню, открыть URL станции - двойной клик (fb2k v2.x и если есть в тегах))
- панели "Peakmeter Spectrum" добавлены в отдельные сплиттеры и теперь отображают контекстное меню (ПКМ) - стало удобней загружать, настраивать и сохранять предустановки
- переделано огромное количество меню для SMP панелей (новые функции, подсказки и др.)
- кнопка "Skroll" теперь работает для каждого вида плейлиста отдельно
4. Другие мелкие доработки и исправления...
Сообщение #551 pinyuszka » 21.12.2023, 13:56
hi kutuzof!
With foobar2000 v2.1 [x86], my Biography setting is broken.
I set a cache of 1 day because I don't want the images to accumulate.
a DarkOne4Mod v1.0 folder with the images was created above my DarkOne4Mod v1.0 (SMP) - fb2k v2.1 folder.
After some time, the same pictures are loaded on the Biography interface. It doesn't work as intended. I did not experience a similar problem with the previous version v2.0. Is it a unique problem or does it affect version v2.1?
pinyuszka
С нами: 4 года
Сообщение #552 gajdar79 » 21.12.2023, 18:48
Hi kutuzof!
Can I upgrade from version 2.0 to version 2.1 without losing my settings and appearance adjustments, etc.? Or does the new version completely reinstall everything? Thanks
gajdar79
Сообщение #553 kutuzof » 21.12.2023, 19:15
pinyuszka, прочитайте этот пост внимательней: https://foobar2000.ru/forum/viewtopic.php?p=83905#p83905
gajdar79, просто скачайте инсталлятор с официального сайта и установите поверх своей версии.
Последний раз редактировалось kutuzof 21.12.2023, 21:36, всего редактировалось 1 раз.
Сообщение #554 gajdar79 » 21.12.2023, 19:35
kutuzof:просто скачайте инсталлятор с официального сайта и установите поверх своей версии.
As I understand it, I can't install your enhanced version of DarkOne4Mod v1.0 (SMP) // 2.1 [x86] without losing my settings. So I can only change to the official version from foobar2000.org, without your modifications in the new release, but will it keep my settings? Is that right? Sorry for the possibly stupid questions.
gajdar79
Сообщение #555 kutuzof » 21.12.2023, 19:46
gajdar79:As I understand it, I can't install your enhanced version of DarkOne4Mod v1.0 (SMP) // 2.1 [x86] without losing my settings.
скорее всего нет :sad:
Добавлено спустя 1 час 56 минут:
pinyuszka:It doesn't work as intended.
pinyuszka, новая версия Biography v 1.4.2 от Wil-B должна решить вашу проблему.
Сообщение #556 pinyuszka » 22.12.2023, 12:38
hi kutuzof!
I saved the settings of version 2.0 to the new version 2.1 with the foo_jesus add-on. Everything worked properly. Wil-B Biography v 1.4.2, recommended by you, solved the problem... I copied the foo_spider_monkey_panel.dll.cfg file again from the configuration folder, so Biography works as intended ;)
I have a visual problem, the letters in the picture are scrambled. This window appears when I hold the mouse over the header. how can i stretch the lines?
pinyuszka
С нами: 4 года
Сообщение #557 kutuzof » 22.12.2023, 21:28
pinyuszka:how can i stretch the lines?
pinyuszka, я не знаю, но вы можете просто отключить это всплывающее окно если оно вам не нужно.
Сообщение #558 pinyuszka » 22.12.2023, 22:09
kutuzof:я не знаю, но вы можете просто отключить это всплывающее окно если оно вам не нужно.
This is the best solution, I don't even need this window, it's completely unnecessary.
thanks for the quick response!
pinyuszka
С нами: 4 года
Сообщение #559 Alle_da » 05.01.2024, 13:30
С новым годом! Уважаемый автор, спасибо за разработку! Подскажите, пожалуйста, можно ли активировать регулятор громкости и индикаторы уровней при использовании upnp сетевого ресивера? Добавил в сборку плагин для этого UPnP MediaRenderer Output. Очень хотелось бы регулировать громкость штатной крутилкой и видеть индикаторы. Можно ли как-то настроить? Спасибо!
Alle_da
С нами: 3 года 7 месяцев
Сообщение #560 HankH » 10.01.2024, 19:14
Спасибо автору за отличную сборку DarkOne4Mod v1.0 (SMP) // 2.1 [x86].
Помимо интерфейса доставило присутсвие радиостанций в плей-листе. И, особенно, в несжатом (losless) формате.
Переполз со сборки широко известного в узких кругах audiophile, который устроил истерику и перевёл свой сайт и поддержку на укро\английский язык и увёл в зону, недоступную для РФ.
Понравилось всё. Легко настроил на внешний ЦАП.
Вопрос:
Поскольку перешёл на версию 2.1 с 1.5.7, есть ли смысл в 64-битной версии F2K? Даст ли она какие-то преимущества в сравнении с x86?
На первый взгляд, бОльшие размеры буферов, чуть более быстрая работа с огромными файлами при кодировании-декодировании, дают преимущество 64-битной версии.
Также возможный отказ от поддержки 32-битных приложений\компонент F2K со стороны Windows (со временем) заставит всё равно переходить на 64 бита.
HankH
С нами: 7 лет 3 месяца
