foobar2000 v2.25
Сообщение #1 VEG » 10.05.2025, 00:51
Вышел foobar2000 v2.25! Предыдущая версия: foobar2000 v2.24.
  • Built-in UPnP media renderer, both client (play to another device) and server (be controlled by another device).
    • Other foobar2000 instances on your local network, with UPnP remote control feature active, will be listed as output devices.
    • foobar2000-to-foobar2000 playback shows tags with album covers on the other end, using Ogg FLAC as stream container.
  • Media Library improvements, most notably:
    • Can natively index FTP/WebDAV/SMB network shares.
    • Improved response to enabling/disabling/installing/uninstalling decoders - only reloads info from affected music files.
  • Codecs, most notably:
    • FFmpeg updated to 8.0, added native support for xHE-AAC decoding.
    • Rewritten Ogg FLAC tag handling, properly implemented embedded album art.
    • Fixed ReplayGain tags not being saved in multichapter Ogg/Opus files.
  • Portable install improvements
    • Changed the way relative paths are handled, so cached tags are no longer forgotten after relaunching from a different path.
    • Made possible so specify no-cover pics as relative path to install location.
  • Converter:
    • Enabled RF64 writing.
    • Fixed Converter failing to function until foobar2000 restart after removal of %TEMP%\foo_converter.
  • Other
    • Added preferences page for network share credentials so you don't have to place them in URLs anymore.
    • Made editing DSP settings momentarily lower output latency to make DSPs appear more responsive.
    • Fixed Properties 'rewrite tags' not working if nothing has been edited.
    • Installer is now hi-DPI friendly.
    • Made system file dialogs invoked out-of-process, to avoid stability issues.
  • See release notes for full list of changes.
VEG M Онлайн
Автор темы, Администратор
С нами: 14 лет 4 месяца
Сообщение #21 VEG » 01.08.2025, 01:15
2025-07-31
  • UPnP streaming reliability improvements.
  • Mac: Fixed main menu rendering bugs (missing checkmarks in submenus, duplicate output device submenu).
VEG M Онлайн
Сообщение #22 VEG » 04.08.2025, 20:21
2025-08-04
  • More robust reading of malformed MP3 LAME tags.
  • Mac: Fixed playlist view crash on specific configuration.
VEG M Онлайн
Сообщение #23 LUR » 23.08.2025, 05:04
2025-08-15
  • UnRAR code updated to unrarsrc-7.1.10. This is just a precaution. Our copy of UnRAR code has all file access capabilities stripped away. There is no indication of recent WinRAR vulnerabilities possibly affecting current or past foobar2000 versions.
  • Fixed potential resampler issues if attempting to upsample very large audio chunks.
  • M4A metadata field mapping updates (atID, cmID, geID, sfID, xid).
  • Mac: Fixed blank filter picker text when clicked "filters" with no filter actually selected.
  • Mac: Properties dialog, when editing a multi line field, dialog content scrolls if needed to show entire content.
2025-08-18
  • Restored $info(cover_url)
  • Windows: ARM build is back, preparing for final release.
  • Windows: Decoding speed test fixed last used bit depth resetting itself to 16-bit.
2025-08-22
  • Fixed a bug in smooth seeking mode that caused audio glitches with DSP settings page open.
  • Fixed multichapter Ogg/Opus files not storing ReplayGain tags.
  • Windows: Fixed stuck low latency mode after opening DSP preferences page.
LUR M Онлайн
Сообщение #24 VEG » 27.08.2025, 07:48
2025-08-26
  • Windows: Fixed Converter failing to function until foobar2000 restart after removal of %TEMP%\foo_converter.
  • Windows: Made possible so specify relative no-cover pics in portable installs.
  • FFmpeg updated to 8.0.
VEG M Онлайн
Сообщение #25 LUR » 02.09.2025, 11:19
2.25
  • Converter:
  • Other
LUR M Онлайн
foobar2000 v2.25.1 preview
Сообщение #26 LUR » 05.09.2025, 22:30
2025-09-04
  • Fixed Ogg FLAC tagging bug that caused metadata to disappear if writing pictures.
  • Made Ogg FLAC tag writer refuse to write pictures too large to fit size permitted by the specification.
  • Mac: Fixed various instances of crashing on malformed UTF-8 in tags.
  • Mac: Preferences / Components fixed incorrect text color in selected row in light mode.
  • Mac: Preferences / Components fixed popup messages causing Preferences window to go behind main foobar2000 window.
  • Mac: Preferences / Media Library fixed wrong icons on SMB folders.
  • Mac: Preferences / DSP made table columns fill whole table.
  • Mac: Fixed annoying grayed "remove" etc commands in playlist if playlist isn't focused when triggering context menu.
  • Windows: Internet Radio dialog fixed missing tab texture in light mode.
  • Windows: Suppressed UPnP initialization if foobar2000 is invoked by installer.
LUR M Онлайн
Сообщение #27 LUR » 08.09.2025, 22:47
2025-09-07
  • Fixed a rare bug causing unwanted changes in titles when editing attached pictures on M4A files containing valid chapter list but with just one chapter.
  • Mac: Further improved handling of malformed UTF-8 tags.
  • Mac: Made Properties dialog not stretch attached pictures that aren't square.
  • Mac: Changed album art viewer behaviors, removed scroll/zoom capability by default which was causing more annoyance than benefit.
  • New parameters: "zoomable" (self-explanatory, restores old behavior) and "square" (makes view always square so square covers cover whole view).
2025-09-08
  • Mac: Album art viewer regression fix, no longer tries to hide itself having nothing to show.
LUR M Онлайн
Сообщение #28 LUR » 10.09.2025, 12:34
2025-09-09
  • Fixed Monkey's Audio seeking bugs - reverted Monkey's Audio library to version 10.93, same as in foobar2000 v2.24 series.
LUR M Онлайн
Сообщение #29 LUR » 13.09.2025, 14:22
2.25.1 released on 2025-09-11
  • Fixed some list control styles not drawing background correctly.
  • Internet Radio dialog fixed missing tab texture in light mode.
  • Suppressed UPnP initialization if foobar2000 is invoked by installer.
LUR M Онлайн
Сообщение #30 LUR » 18.09.2025, 13:34
2025-09-15
  • Fixed incorrect handling of non-alphanumeric characters in network passwords.
  • Mac: Fixed ReplayGain scanner crashing on malformed UTF-8 in tags.
LUR M Онлайн
Сообщение #31 VEG » 22.09.2025, 20:49
2025-09-22
  • Windows: Fixed glitches in playback error log on Wine.
  • Fewer C++ exceptions thrown during app startup.
VEG M Онлайн
Сообщение #32 VEG » 23.09.2025, 20:11
2025-09-23
  • Thorough fix for implicit resampling (WASAPI shared) vs low latency in smooth seeking mode.
  • When doing both implicit resampling and channel remapping, do it in order that costs less CPU (resample then upmix, or downmix then resample).
  • Console now sanitizes bad UTF-8 in received text instead of going off the rails.
  • Fixed a bug that made files where tag reading fails impossible to add to playlist.
VEG M Онлайн
Сообщение #33 VEG » 24.09.2025, 20:00
2024-09-24
  • No longer feeds autoresampled & autoupmixed content to visualizations (2025-09-23 regression).
  • Fixed a bug causing various window positions not to be restored if too close to screen edges.
  • Suppressed flushing of pending visualization data when only running visualization momentarily disappears, fixes visualization going blank when resizing window with just one visualization running.
VEG M Онлайн
Сообщение #34 VEG » 29.09.2025, 22:34
2024-09-29
  • Made more compatible with http://user:pass@host URLs entered in old versions; some no longer worked since special character urlencoding fix.
  • Matroska seeking/chapters fixes:
    • Fixed seeking accuracy regression introduced in 2.24.
    • Verifier no longer complains about decoded vs reported duration mismatch on affected files (did in pre-2.24).
VEG M Онлайн
Сообщение #35 VEG » 30.09.2025, 20:08
2025-09-30
  • Increased size limit for cover pictures embedded in MP4/M4A files to 64MB; made refuse to write covers too large for foobar2000 to read back.
  • Made MP4/M4A publisher field recognized.
  • Fixed false errors when seeking in Matroska/FLAC with "verify integrity of played files".
  • Windows: Made odd-sized covers rendered with correct aspect ratio in Properties dialog.
VEG M Онлайн
Сообщение #36 VEG » 03.10.2025, 20:12
2025-10-02
  • Workaround for "database is readonly" crash.
  • Increased size limit for cover pictures embedded in APE tags; made refuse to write covers too large for foobar2000 to read back.
  • Fixed bad interaction of TAK album art reader with decoder merit management.
  • Enabled album art reading & editing for: AC3/EAC3, DTS.
  • Windows: RTSP appears no longer supported by Microsoft WMA runtime - made fail with correct message.
VEG M Онлайн
Сообщение #37 VEG » 05.10.2025, 15:28
2.25.2 released on 2025-10-04
  • RTSP appears no longer supported by Microsoft WMA runtime - made fail with correct message.
  • Increased size limit for cover pictures embedded in MP4/M4A files or APE tags to 64MB; made refuse to write covers too large for foobar2000 to read back.
  • Made odd-sized covers rendered with correct aspect ratio in Properties dialog.
  • Fixed issues with implicit resampling (WASAPI shared) vs low latency in smooth seeking mode.
  • Fixed glitches in playback error log on Wine.
VEG M Онлайн
Сообщение #38 VEG » 29.10.2025, 20:46
2.25.3 released on 2025-10-29
  • Fixed very old race condition bugs in decoder merit management, potentially causing decoder to be listed twice.
  • Fixed missing info reload when changing stream via toolbar dropdown.
  • Workaround for stuck visualizations if playback ends while foobar2000 is invisible.
  • Fixed LD & ELD AAC not being reliably sent to alternate packet decoders.
  • Fixed Decoding Speed Test not remembering last used DSP chain.
  • Fixed missing winsock init for SMB operations, causing all SMB access to fail if no other network features have been used first.
  • Fixed bad interaction between WebDAV filesystem and media library.
  • Workaround for foo_tags stuck info issue.
  • Workaround for WAV headers claiming zero length.
  • Fixed File Operations link vs portable relative paths.
VEG M Онлайн
Сообщение #39 VEG » 31.12.2025, 09:53
2.25.4 released on 2025-12-30
  • Refined workaround for foo_tags (M-Tags) component bugs. No longer hammers all subsongs when starting playback.
  • Default User Interface: made cycling tabs by keyboard shortcuts cancel tab rename in progress.
  • Converter: Made "no DSP reset" explicitly shown in overview, as it's dangerous if enabled unintentionally.
  • Fixed various regressions with network shares in Media Library preferences page.
  • File Operations: Fixed error with renaming files on redirected portable music folders.
  • Fixed tag writing issues on fragmented/streaming M4A/MP4 files.
  • Fixed bugs related to copy-paste of file-relative locations in portable installs.
VEG M Онлайн
Сообщение #40 VEG » 02.01.2026, 22:27
2.25.5 released on 2026-01-02
  • Corrected a regression in 2.25.4; incomplete removal of foobar2000 v2.0 beta code leftovers resulted in crashing on a fresh profile.
VEG M Онлайн
