foobar2000 под Android
Список разделов › foobar2000 › foobar2000 Mobile Edition
Описание: Мобильная версия для Android и iOS
Сообщение #141 VEG » 16.09.2026, 15:26
2.25.8 released on 2026-07-25
  • Fixed Ogg/Opus files with single chapter not showing correct track numbers.
  • Restored display of total playlist length in playlist summary. If your playlist doesn’t show it, duplicate it then delete old copy.
  • Improved SMB read throughput over high-latency connections.
  • Updated 7-Zip library to 26.02.
  • Updated UnRAR library to 7.2.7.
  • Bug-fixed interaction with file browser apps.
2.25.9 released on 2026-09-04
  • Fixed certain malformed MP4/M4A/M4B files being presented with thousands of chapters.
  • Updated Android development tools.
  • Internal cleanups; smaller app download size.
2.25.10 released on 2026-09-16
  • Fixed incorrect status bar color on Android 16.
  • Improved compatibility with specific UPnP renderers.
  • Fixed multiple bugs in smooth seeking implementation.
VEG M Онлайн
С нами: 14 лет 6 месяцев
Сообщение #142 VEG » 16.10.2026, 09:32
2.26 released on 2026-10-15
  • Updated appearance of first run screens.
  • Added options for controlling image cache behavior, made possible to entirely disable image cache.
  • Added configuration export/import feature. Settings can now be transferred between installations on different devices.
  • Allowed editing of media server bookmark names (not only URLs).
  • Made accept \\server\share paths - they're automatically turned into smb://server/share format.
  • Replaced old resampler (SSRC) with ARDFTSRC + Speex resamplers.
  • In folder browsing mode, "add to playlist" now expands multi chapter files into separate playlist items.
  • Made "add to playlist" operations more useful: destination playlist is automatically shown without having to navigate all the way up; can delete/rename playlists directly from the menu.
  • Added "edit icon URL" for radio bookmarks.
  • Image manipulation routines cleaned up, disabled some obscure and undocumented skin features.
  • Added support for decoding TrueHD & MLP streams in Matroska.
  • If Internet Radio or Media Servers are hidden/inlined, full versions are now accessible in Tools / Utilities, so you can edit bookmarks without having to temporarily restore full view.
  • Attempt to play a password-protected resource such as radio stream now shows a password prompt.
  • Improved handling of M3U playlists with internet radio links.
  • Can bookmark radio streams from M3U playlists.
  • Android specific changes:
    • Rewritten Internet Radio search UI, now consistent with iOS version, no more scrolling thru pop-up lists of countries/languages/tags.
    • Enabled reading of EXIF orientation info from album cover pictures.
VEG M Онлайн
Сообщение #143 VEG » 28.10.2026, 21:03
2.26.1 released on 2026-10-28
  • M3U loader behavior update
    • Requires additional lines to recognize chapters in referenced media.
    • Opens playlists as fast as in previous foobar2000 versions.
  • Minor stability issues fixed.
  • Updated splash screen.
  • Fixed spurious seek events when touching seekbar.
VEG M Онлайн
Сообщение #144 VEG » 09.11.2026, 22:22
2.26.2 released on 2026-11-09
  • Replaced DUMB module decoder with latest and greatest OpenMPT with full configuration.
  • New DSPs from mudlord: Pitch Shift, Tempo Shift, Playback Rate Shift.
  • Renamed classic Push the Tempo DSP to Audio-Stretch, matching desktop foobar2000 naming.
  • Improved SMB network share compatibility, with macOS shares in particular.
  • UPnP: Made send icy-meta style song titles to devices that ask for them.
  • Fixed missing local network permissions prompt when starting FTP server.
VEG M Онлайн
Сообщение #145 VEG » Сегодня, 08:03
2.26.3 released on 2026-11-16
  • Now uses FDK-AAC to decode xHE-AAC.
  • Various WebDAV share handling fixes.
  • Fixed specific HE-AAC files not playing gaplessly.
  • Fixed crashing on Context Menu Proceed, regression since 2.26.
VEG M Онлайн
