Инструменты пользователя
Инструменты сайта
foobar2000:plugins_for_0.9.x:mslive_foo_input_mslive
MSLive (foo_input_mslive)
Описание
Поддержка протоколов сетевого радио MMS и RSTP.
Примеры
Пример правильных ссылок:
mms://www.stream.com/stream
rtsp://www.stream.com/stream
mslive://|mms://www.stream.com/stream|/
mslive://|mms://www.stream.com/stream|live|/
mslive://|c:\stream.mp3|/
Чтобы уберечь foobar от использования других декодеров, ссылка должна быть такой:
mms://www.stream.com/stream.wma рекомендуем указывать как mslive://|mms://www.stream.com/stream.wma|/
Пример верного плейлиста asx:
mslive://|http://www.stream.com/stream.asx|/
mslive://|http://www.stream.com/stream.asx|list|/
c:\stream.asx
Требования
Изменения
0.3.7
  • fixed a bug that was introduced when fixing another bug
0.3.6
  • fixed another tiny little bug
0.3.5
  • fixed tiny little bug that try to play CDDA: 0.3.4 * fixed a minor bug of crashing from the Add Location dialog * fixed incorrect display of utf-8 encoded asx 0.3.3 * fixed always play the same entry as if hide playlist entries is enabled * “Add Location (mslive)” item now accepts mslive location syntax as well 0.3 * heavily rewrite * ENTREF will not be expanded, even when tagging (only local asx is supported) * only root asx entries will be listed, recursive asx will be handled internally (only one level of nesting) * support source switch and msn radio stream type * dynamic display of meta data of the stream * able to detect if is asx * will loop through all the reference urls if the first cannot connect ===== Ссылки ===== * Страница закачки * Дискуссионная страница плагина (англ.)
foobar2000/plugins_for_0.9.x/mslive_foo_input_mslive.txt · Последние изменения: 2008/08/27 09:12 (внешнее изменение)
