Сборка Phenix®[Foobar2000 v.0.9.6.9] (от 3.11.2009)
Сообщение #1 Phenix » 26.08.2008, 00:00
Foobar2000 v.0.9.6.9 Phenix®
Версия: 2.5 (3.11.2009)
Download (9.12 Mb):
Плагины (все лишнее убрал) :
Core (2009-08-22 13:25:22)
   foobar2000 core 0.9.6.9
foo_abx.dll (2009-06-07 15:25:26)
   ABX Comparator 1.3.4
foo_ac3.dll (2007-05-04 08:29:44)
   AC3 decoder 0.9
foo_albumlist.dll (2009-06-07 15:26:58)
   Album List 4.3.1
foo_cdda.dll (2009-06-07 15:26:40)
   CD Audio Decoder 2.1.4
foo_cdtext.dll (2007-12-29 03:38:40)
   CD-TEXT Reader 0.2
foo_converter.dll (2009-06-07 15:26:38)
   Converter 1.2.1
foo_discogs.dll (2009-06-27 07:39:22)
   Discogs Tagger 1.19
foo_dsp_continuator.dll (2007-04-11 09:29:04)
   Continuator 0.4.1
foo_dsp_crossfader.dll (2008-07-01 23:40:50)
   Gapless Crossfader 0.3.4 (Intel SSE)
foo_dsp_crossfeed.dll (2009-02-10 19:18:24)
   Crossfeed 1.1.1
foo_dsp_std.dll (2009-06-07 15:26:54)
   Standard DSP Array 1.0
foo_fileops.dll (2009-06-07 15:25:30)
   File Operations 2.1.2
foo_freedb2.dll (2009-06-07 15:25:50)
   freedb Tagger 0.6.1
foo_input_dts.dll (2009-05-02 12:58:30)
   DTS decoder 0.2.4
foo_input_monkey.dll (2009-05-01 13:40:52)
   Monkey's Audio Decoder 2.1.4
foo_input_mslive.dll (2009-01-05 19:46:44)
   mslive 0.4.9 (SSE)
foo_input_std.dll (2009-06-07 15:26:30)
   Standard Input Array 1.0
foo_lnk.dll (2007-01-22 12:05:16)
   Shell Link Resolver 1.2
foo_midi.dll (2007-05-04 08:29:44)
   MIDI synthesizer host 1.7
foo_navigator.dll (2007-08-04 14:36:46)
   Navigator 0.63
foo_out_ks.dll (2007-05-04 08:29:44)
   Kernel Streaming Output 1.2.2
foo_playlist_bind.dll (2007-06-27 04:57:38)
   Playlist Bind 3.2
foo_rating2_beta2.2.dll (2009-07-22 22:48:32)
   Foo_Rating2 BETA 2.2
foo_rgscan.dll (2009-06-07 15:26:22)
   ReplayGain Scanner 2.0.8
foo_run.dll (2009-06-07 14:15:18)
   Run services 0.3.7
foo_ui_columns.dll (2009-06-15 01:18:06)
   Columns UI 0.3.7.8
foo_ui_egoh2.dll (2007-07-22 00:16:34)
   egoh user interface 2.0.0
foo_ui_std.dll (2009-06-07 15:27:04)
   Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-15 23:22:24)
   Album Art Panel 0.2.7.1
foo_uie_albumlist.dll (2007-06-08 15:58:42)
   Album list panel 0.2.2
foo_uie_explorer.dll (2009-05-11 05:37:30)
   Explorer Tree 1.04.7c
foo_uie_lyrics.dll (2008-12-12 12:39:20)
   Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01]
foo_uie_playlists_dropdown.dll (2007-09-29 01:03:32)
   Playlists Dropdown 0.6 alpha 4
foo_uie_tabs.dll (2007-09-08 21:08:54)
   Tabbed panel modified 0.2.6
foo_uie_trackinfo_mod.dll (2007-05-04 08:29:44)
   Track info panel mod 0.8.0 beta [Dec  6 2006 - 14:21:24]
foo_uie_vis_egoh.dll (2007-05-04 08:29:44)
   Egoh Spectrum analyser (uie) 1.1.2
foo_uie_wmpvis.dll (2008-02-16 06:10:44)
   WMP Visualizations 0.1.3 (SSE)
foo_unpack.dll (2009-06-07 15:25:18)
   RAR reader 1.2
   ZIP/GZIP reader 1.0
foo_version.dll (2009-04-16 10:17:12)
   Components versions viewer 0.4
foo_vis_shpeck.dll (2009-08-08 00:20:50)
   Shpeck - Winamp vis plugins wrapper 0.3.5
foo_whatsnew.dll (2008-07-03 01:45:50)
   Feature Watcher 1.0.4
Достоинства :
+ Простая и удобная сборка
+ Набор всех самых необходимых кодеков и плагинов
+ Управление медийными клавишами
+ WMP визуаляция
+ Рейтинги проигрываемых треков
+ RAR\Zip\GZip -reader
+ Winamp эмулятор
b]Минусы:[/b]
1) Компонент foo_uie_trackinfo_mod.dll (по умолчанию не активен) требует установки C++ 8.0 runtime libraries, можно скачать тут : vcredist_x86_sp1.exe (2.59 MB)
8) P.S.: есть еще один аналог сборки, специально для ноутов (совсем Lite и лишь самое необходимое) - если надо выложу!!!
Последний раз редактировалось Sp1ke 13.11.2009, 08:23, всего редактировалось 1 раз.
Phenix M
С нами: 19 лет
Сообщение #2 Phenix » 26.08.2008, 00:17
при необходимости обновления плагинов - сообщайте (т.к. самому сложно отслеживать)
в программировании не силен, так что может понадобиться помощь!
жду предложений, советов и комментариев...
Последний раз редактировалось Phenix 26.08.2008, 00:19, всего редактировалось 1 раз.
Phenix M
С нами: 19 лет
Сообщение #3 Максим » 26.08.2008, 06:29
Исполинский размер у сборки. ;) Нужны ли все эти компоненты?
С нами: 18 лет 8 месяцев
Сообщение #4 Максим » 26.08.2008, 06:32
Да, и Playback Statistics Custom нестабилен. Советую заменить на официальный foo_playcount.
Сообщение #5 meDveD » 26.08.2008, 11:46
Phenix
- за плагинами легко следить здесь например, или на сайте вышеотписавшего товарища
- треть плагинов можно выкинуть.
- настройки надо хранить в папке с фубаром, как у тебя,
http://ipicture.ru/uploads/080826/10687/NFp58Qzin1.png
непонятно зачем папка Apllication Data/foobar2000
- вот это при выкладывании сборок удалять нужно
http://ipicture.ru/uploads/080826/10687/k6Se7mGUZm.png
В итоге сборка становиться размером в 9.77 Mb уже, это лишь удалив ненужное, а если ещё и плагины.. то и совсем небольшая..
Последний раз редактировалось meDveD 26.08.2008, 11:48, всего редактировалось 1 раз.
С нами: 19 лет
Сообщение #6 Phenix » 26.08.2008, 15:23
2Maxim_289
разберусь!
2meDveD_spb
СПА-СИ-БО! подправил!
Phenix M
С нами: 19 лет
Сообщение #7 tribal » 12.09.2008, 22:38
распаковал сборку в папку c:\Program Files (x86)\Foobar2000\  (система vista x64)
отсутствуют кнопки и регулятор громкости
как это исправить?
tribal
С нами: 19 лет
Сообщение #8 Phenix » 26.03.2009, 00:56
наконец обновил сборку! есть глюки (?) - пишите.
(буду признателен за грабли и их решение, т.к. сам не особо "секу")
жду преложений по совершенствованию!
Phenix M
С нами: 19 лет
Сообщение #9 rhino » 05.07.2018, 01:46
Помогите вернуть потерянную (после крушения винта) любимую версию проигрывателя. последнюю версию скачал, а она ape файлы играть умеет а перематывать нет... :fie:
Спасибо за внимание и понимание :) :pray:
rhino
С нами: 7 лет 5 месяцев
