foobar2000 v1.4.3
Сообщение #1 VEG » 20.02.2019, 13:39
Вышла финальная версия foobar2000 v1.4.3! Предыдущая версия: foobar2000 v1.4.2.
  • Fixed disappearing metadata and playlist content corruption with certain internet radio playlists.
  • Fixed high CPU usage with read-ahead options active.
  • Converter: Fixed broken save-as dialog with | character in encoder names.
  • Made foo_ui_std.dll & foo_input_std.dll report version number of the foobar2000 release that they came with, as some people seem to mix binaries from different releases then run into issues.
  • Made possible to fall back to another decoder with WMA files that standard WMA decoder doesn't accept.
  • Fixed disappearing & appearing 'version' file in library configuration folder.
  • Updated FFmpeg to 3.4.5.
  • Fixed certain AIFF files not playing (beta 2).
  • Restored foobar2000 version number in HTTP user-agent string (beta 2).
  • Added an option to force HTTP CONNECT with proxy servers (beta 2).
  • Fixed 1.4 regression causing odd behaviors when the currently playing track is removed from playlist (beta 2).
  • Fixed 1.4 regression causing certain combinations of shuffle and playlist operations to crash (beta 2).
  • Fixed 1.4 regression with missing HTTP host field in proxy server requests (beta 3, beta 5).
  • Fixed a bug causing random crashes when decoding Vorbis (possibly also MP3 and AAC) due to bad parameters fed to FFmpeg (beta 4).
  • Converter: Made malformed UTF-8 in source file tags no longer cause conversion to FLAC to fail (beta 5).
  • Fixed ReplayGain alter file content crash (final).
Автор темы, Администратор
С нами: 13 лет 7 месяцев
Сообщение #2 postED » 21.02.2019, 01:21
VEG:Made foo_ui_std.dll & foo_input_std.dll report version number of the foobar2000 release that they came with, as some people seem to mix binaries from different releases then run into issues
Петеру видимо надоело разбиратся в краш-репортах, получаемых от криворуких ССЗБ-шников :biggrin:
Сообщение #3 Ozi » 15.03.2019, 19:33
Звучание стало ужасным - новый FFmpeg 3.4.5 - свистопердит!!! :cry:
Остаюсь на foobar2000 v1.4.2
Ozi M
Сообщение #4 postED » 15.03.2019, 20:22
Ozi, ffmpeg используется только для декодирования aac, ворбиса и мп3. Проверил у себя - изменений никаких, даже пруфану скрином. Ищите проблему где-то на своей стороне.
Сообщение #5 Ozi » 15.03.2019, 20:29
postED - очень странно я слышу разницу буду искать причину...
Ozi M
Вернуться в Новости плеера
