foobar2000 v1.6.8
Сообщение #1 VEG » 07.10.2021, 15:19
Вышла финальная версия foobar2000 v1.6.8! Предыдущая версия: foobar2000 v1.6.7. Версия для Windows XP: foobar2000 v1.5.
  • Fixed visual glitches when scrolling lists horizontally with mouse wheel through Logitech software.
  • Improved output format negotiation with exclusive output.
  • Fixed failure to install components from store-mode (uncompressed) zip archives.
  • Improved handling of malformed FLAC files, prevented crash from too many cuesheet entries.
  • Correct reporting of AC3 channel count in MP4 files even without AC3 component installed (before it would incorrectly report stereo).
  • Allowed UTF-8 cuesheets without UTF-8 header.
  • Fixed htmlspecialchars misuse in component update list / component page link.
  • Mapped MP4 @mvn field to "movement name".
  • Prevented the same folder from being added more than once to the Media Library.
  • Properties dialog: deferred logging of user-entered field names for the dropdown list until the tags are saved, effectively preventing typos from being remembered.
  • Fixed a bug causing alt+f4 (and possibly other keyboard events) to be disregarded if mouse pointer is above specific interactive portion of a window (list controls, buttons in editboxes).
  • Improved handling of files with malformed APE tags - some files were entirely unplayable.
  • More thorough 'remove tags' for Vorbis, Opus and Musepack.
  • Fixed text truncation in ReplayGain Scanner preferences page.
  • Made possible to add attached pictures by drag and drop to relevant Properties dialog page.
Автор темы, Администратор
С нами: 14 лет 1 месяц
Сообщение #2 Гармонист » 10.10.2021, 11:41
А где ссылка на "финальная версия foobar2000 v1.6.8!"? Только бетта 2.
Гармонист
Сообщение #3 LUR » 11.10.2021, 04:47
Гармонист:А где ссылка на "финальная версия foobar2000 v1.6.8!"? Только бетта 2.
Действительно.
LUR M Онлайн
С нами: 13 лет 6 месяцев
Сообщение #4 VEG » 11.10.2021, 08:52
Ух, походу меня проглючило. Почему-то показалось, что был релиз =) Заполнял в дороге с телефона, может поэтому. Исправил.
Сообщение #5 VEG » 14.10.2021, 07:24
beta 3
  • Made possible to add attached pictures by drag and drop to relevant Properties dialgo page.
Сообщение #6 VEG » 18.10.2021, 17:19
Beta 2
  • Fixed Properties crash regression from beta 1
Beta 3
Beta 4
  • Addressed large playlist scrolling bugs caused by Logitech software bug workaround introduced in beta 1.
Сообщение #7 VEG » 21.10.2021, 11:09
Beta 5
  • Addressed unnecessary album art reloads on tag edit, playcount increment, etc introduced in beta 1.
Сообщение #8 VEG » 23.10.2021, 09:43
Beta 6
  • Addressed failure to parse tag blobs in tag_processor since beta 1 caused by another fix, causing some add-ons to malfunction.
Сообщение #9 matss » 28.10.2021, 16:31
Здравствуйте ! Установил бесплатную версию Foobar2000 v1.6.8 beta6, пытался подключить транспорт (для ЦАП) Amanero - OEM Combo384 to I2S/DSD.
В общем в настройках программы не могу разобраться.
matss M
С нами: 4 года 7 месяцев
Сообщение #10 Гармонист » 09.11.2021, 01:01
Заметил, что на одном треке FLAC в одном месте происходит слабый щелчок. Причем иногда бывает, что щелчка нет и он может быть разной громкости. Такое впечатление, что попадает какая то случайная информация. Версию 1.6.8 пока не ставил. Вроде в ней есть сообщение об устранении сбоев при воспроизведении FLAC.
Гармонист
Сообщение #11 VEG » 09.11.2021, 14:59
Вышел релиз, вместе с новым foobar2000 v1.5.8 для Windows XP.
Сообщение #12 Гармонист » 09.11.2021, 18:48
"Вышел релиз, вместе с новым foobar2000 v1.5.8 для Windows XP.". А случайно 1.6.8 финал не вышел? Чем черт не шутит.
Гармонист
Сообщение #13 t830x » 09.11.2021, 18:51
Гармонист, а в самое первое сообщение поднять глаза?
t830x M
Сообщение #14 Гармонист » 09.11.2021, 20:29
Так это "первое сообщение" от 07.10.2021, 16:19 и тогда точно финальной версии не было и поэтому смотреть туда не целесообразно.
Гармонист
  • 0
Сообщение #15 VEG » 09.11.2021, 23:27
Гармонист:А случайно 1.6.8 финал не вышел?
Под "релиз" и подразумевается "финал". Сперва выходят альфы, беты, потом релиз-кандидат, а потом и сам релиз.
Гармонист:Так это "первое сообщение" от 07.10.2021, 16:19 и тогда точно финальной версии не было и поэтому смотреть туда не целесообразно.
Первое сообщение всегда редактируется по мере выхода бета-версий и подготовки релиза.
Сообщение #16 t830x » 10.11.2021, 12:37
Гармонист, за столько лет на форуме не понять как здесь обновляются новости о новых версиях?
t830x M
