VEG » 10.05.2025, 00:51
Вышел foobar2000 v2.25! Предыдущая версия:
foobar2000 v2.24.
- Built-in UPnP media renderer, both client (play to another device) and server (be controlled by another device).
- Other foobar2000 instances on your local network, with UPnP remote control feature active, will be listed as output devices.
- foobar2000-to-foobar2000 playback shows tags with album covers on the other end, using Ogg FLAC as stream container.
- Media Library improvements, most notably:
- Can natively index FTP/WebDAV/SMB network shares.
- Improved response to enabling/disabling/installing/uninstalling decoders - only reloads info from affected music files.
- Codecs, most notably:
- FFmpeg updated to 8.0, added native support for xHE-AAC decoding.
- Rewritten Ogg FLAC tag handling, properly implemented embedded album art.
- Fixed ReplayGain tags not being saved in multichapter Ogg/Opus files.
- Portable install improvements
- Changed the way relative paths are handled, so cached tags are no longer forgotten after relaunching from a different path.
- Made possible so specify no-cover pics as relative path to install location.
- Converter:
- Enabled RF64 writing.
- Fixed Converter failing to function until foobar2000 restart after removal of %TEMP%\foo_converter.
- Other
- Added preferences page for network share credentials so you don't have to place them in URLs anymore.
- Made editing DSP settings momentarily lower output latency to make DSPs appear more responsive.
- Fixed Properties 'rewrite tags' not working if nothing has been edited.
- Installer is now hi-DPI friendly.
- Made system file dialogs invoked out-of-process, to avoid stability issues.
- See release notes for full list of changes.
Скачать:
https://www.foobar2000.org/download
- VEG
- Автор темы, Администратор
- С нами: 14 лет 2 месяца
LUR » 02.09.2025, 11:19
2.25- Built-in UPnP media renderer, both client (play to another device) and server (be controlled by another device).
- Converter:
- Other
- LUR
- Модератор
- С нами: 13 лет 8 месяцев
