foobar2000 v2.26 preview
Сообщение #1 VEG » 10.10.2025, 20:33
Вышел foobar2000 v2.26! Предыдущая версия: foobar2000 v2.25.
  • Improved recovery of malformed UTF-8 text in various tag formats.
  • Made malformed UTF-8 tags text reported in integrity verifier.
  • MP4 tagging improvements:
    • Tagtype info (Apple, Nero)
    • No longer writes Nero tags by default for single chapter files, only for multi chapter where other tagging formats can't store per track tags.
    • Added support for more rarely used Apple tag elements.
    • No longer alters binary structure of Apple tag elements which are not affected by edits.
  • Monkey's Audio decoding moved to FFmpeg, no longer including Monkey's Audio library with foobar2000 setup.
    • You can once again install Monkey's Audio decoder component to replace built-in FFmpeg decoder.
  • New info field: container (MP4, Matroska, Ogg, etc)
  • New title formatting field: %_cpu_arch%
  • Mac: made playlist view receive copy/paste from Finder
  • Mac: New icon from Apple Icon Composer
  • Mac: Built with Xcode 26, enabled macOS Tahoe looks.
  • Mac: Install components by drag&drop from Finder to components list.
  • Mac: Playlist Manager columns can be toggled.
  • Added drag&drop from Internet Radio pages to playlist.
  • Attempt to play a password-protected resource such as radio stream now shows a password prompt.
  • Converter: Better error messages when receiving unexpected data format change in mid-conversion; made discard blank chunks before checking for format match.
  • Equalizer now accepts presets via drag&drop from Explorer/Finder.
  • Workaround for foo_tags issue [being backported to 2.25.x]
  • Workaround for WAV headers claiming zero length [being backported to 2.25.x]
  • Fixed File Operations link vs portable relative paths [being backported to 2.25.x]
Автор темы, Администратор
С нами: 14 лет 1 месяц
Сообщение #41 LUR » 18.03.2026, 06:08
2026-03-17
  • Windows: Implemented alternate, more resource-efficient method of finding radio-browser servers.
  • Improved recovery from momentarily unplugged audio device while paused.
  • Fixed missing URL-decode of WebDAV file names being shown.
  • Refactored filename sanitization code (Converter, File Operations), actual behavior should not change.
  • Fewer C++ exceptions thrown when reading file tags.
LUR M Онлайн
С нами: 13 лет 6 месяцев
Сообщение #42 LUR » 19.03.2026, 15:33
2026-03-18
  • Attempted fix for crashing in new radio-browser server finder.
2026-03-19
  • Fixed lock up on specific album art tag update operations.
  • Mac: Included Playback Statistics v3.1.9.
LUR M Онлайн
Сообщение #43 LUR » 24.03.2026, 17:29
2026-03-23
  • Windows: Fixed lock up on specific playlist + album art + auto sizing column use pattern.
  • Refactored MP4/M4A tag update code, should not affect output.
LUR M Онлайн
Сообщение #44 VEG » 05.04.2026, 14:23
2026-03-27
  • Added experimental float8 PCM support.
Сообщение #45 LUR » 22.04.2026, 05:40
2026-04-17
  • Fixed playlist search incorrectly refocusing first item in some scenarios.
  • UPnP renderer: Made accept MP3 (audio/mpeg) streams.
  • Windows: Updated zlib to 1.3.2. Note that system-bundled zlib is used on all other platforms.
  • Mac: Fixed audio latency calculation bug that resulted in instability with smooth seeking mode.
  • Mac: Included Playback Statistics v3.1.10.
2026-04-20
  • Revised UPnP renderer code, implemented various missing methods required by the standard; made compatible with various popular UPnP remote control applications.
  • Windows: Made various DSP configuration dialogs not crash if invoked off-main-thread, which certain unmaintained old component does.
LUR M Онлайн
Сообщение #46 LUR » 28.04.2026, 12:41
2026-04-27
  • UPnP renderer compatibility improved further (M-SEARCH handling, correct content type in SOAP responses).
  • Windows: Keyboard shortcuts made show correct label for "context menu" key.
LUR M Онлайн
Сообщение #47 LUR » 01.05.2026, 12:14
2026-04-30
  • UPnP output: Enabled streaming to OpenHome devices.
  • UPnP renderer: Implemented SetNextAVTransportURI method to allow gapless playback with compatible clients.
  • Fixed incorrect channel mapping in 6.1 FLAC files without explicit channel mask field.
  • Improved remapping of rear-center channel when playing to 5.1-side speakers.
LUR M Онлайн
Сообщение #48 LUR » 05.05.2026, 10:40
2026-05-04
  • Made send Windows version number when checking for component updates.
  • Will only install component updates flagged compatible with system it's running on.
LUR M Онлайн
Сообщение #49 LUR » 08.05.2026, 01:48
2026-05-07
  • Improved UPnP renderer discovery reliability.
  • Enabled audio/x-wav type in UPnP renderer.
LUR M Онлайн
Сообщение #50 LUR » 09.05.2026, 02:36
2026-05-08
  • UPnP renderer lockup regression fix.
  • Improved WebDAV reliability.
LUR M Онлайн
Сообщение #51 LUR » 20.05.2026, 05:07
2026-05-14
  • Upgraded network (HTTPS etc) encryption code on both Windows and macOS. TLS v1.3 is now supported, if your operating system supports it.
  • Mac: ftpes:// is currently not supported due to technical limitations of Apple's Network.framework.
  • Fixed "remove chapters" not working of Ogg files with chapters.
  • Windows: Fixed some windows discarding multimedia keyboard events.
  • Added Help / Search Query Syntax.
  • Mac: Implemented real Help menu.
  • Fixed static HTTP files being perceived as radio streams and looped indefinitely with HTTP seeking disabled in preferences.
  • Fixed another UPnP discovery regression.
2026-05-15
  • UPnP resource leak regression fixed.
  • Other UPnP bugs fixed.
  • Windows: New VC runtime.
2026-05-16
  • ARDFTSRC resampler update.
  • UPnP resource leak regression really fixed.
  • Windows: Fixed "suppress HTTPS certificate checks" regression from build 2026-05-14.
  • Windows: Also fixed ftpes:// connections failing if the server doesn't have a trusted certificate.
2026-05-19
  • Resolved UPnP discovery disagreement with BubbleUPnP.
LUR M Онлайн
Сообщение #52 Azaza » 21.05.2026, 01:01
2026-05-20
  • Windows: Improved UPnP renderer initialization if the machine has virtual network adapters.
  • Windows: Improved Converter WAV writing CPU usage.
Не используйте конвертер в этой версии, он сломан! https://hydrogenaudio.org/index.php/topic,129576.0.html
С нами: 9 лет 9 месяцев
Сообщение #53 LUR » 21.05.2026, 15:48
2026-05-21
  • Windows: Converter regression fix - last samples were missing when encoding through external encoder.
LUR M Онлайн
Сообщение #54 LUR » 26.05.2026, 22:39
2026-05-26
  • Fixed UPnP incompatibility with Denon receivers introduced in build 2026-05-15.
  • Windows: Fixed Converter crash regression from build 2026-05-20.
LUR M Онлайн
Сообщение #55 LUR » 16.06.2026, 17:43
2026-06-09
  • Prevented specific search queries with too many nested or chained operators from crashing foobar2000 with a stack overflow.
  • Fixed earlier 2.26 regression causing playlist search to be stuck showing "working" state if results haven't changed from previous lookup.
  • Fixed a longtime UPnP search bug affecting discovery of specifc rare devices.
  • Converter: made show output of command-line encoder program in error popup if conversion has failed.
  • Improved handling of M4A tags with blank values.
  • Improved handling of Matroska Segment Title field.
2026-06-10
  • Converter: Made show detailed error messages when encoding via temp file as well.
  • Converter: Restored encoder process priority class mapping.
  • Mac: Fixed obscure file path mangling bug in helper code, no known symptoms.
LUR M Онлайн
Сообщение #56 LUR » 18.06.2026, 21:00
2026-06-18
  • More spec-compliant writing of FLAC/Vorbis/Opus cover art (number of colors field).
  • Converter: More reliable reading of encoder error logs.
  • Converter: Worked around FLAC refusing to encode odd-length 24-bit files since recent changes.
  • Windows: Made respect filesystem::open_shareable flag for opening local files (opens with all FILE_SHARE_*).
LUR M Онлайн
