JSplitter v4.4.2 / 3.9.10 [23.11.2026]
  • 12
Особенности функционала:
ПРИМЕЧАНИЕ О ВЕРСИЯХ
АНГЛИЙСКАЯ ВЕРСИЯ
РУССКАЯ ВЕРСИЯ
Версия 3.9.10 (для пользователей Windows 7)
АНГЛИЙСКАЯ ВЕРСИЯ
РУССКАЯ ВЕРСИЯ
Краткое руководство
Программный интерфейс
window.RadioButtons([a, b]);
Свойства:
(readonly) String Name;
(read, write) String Text;
(read, write) boolean Hidden;
(read, write) boolean Locked;
(read, write) int X;
(read, write) int Y;
(read, write) int Width;
(read, write) int Height;
Методы:
void Show(show = true);
Свойства:
(readonly) ushort ID;
(read, write) Function Click;
(read, write) uint State;
Методы:
void Move(x, y);
void Resize(width, height);
путями:
switch(id) {
case a.ID:
do_something();
ПОЛНАЯ ДОКУМЕНТАЦИЯ ПО API
https://dima-lur.github.io/jsplitter/
Пример конфигурации
Пример от zeremy
Изменения
Версия 4.4.2 [23.11.2026]
С нами: 14 лет
Сообщение #561 LUR » 15.10.2026, 18:45
yeyo:When using the handwriting pad to input text, on_char could not be triggered, resulting in the inability to input letters into the input box.
Thanks for the report. I checked this and handwriting input is already delivered to on_char after the IME composition is committed (for example, by pressing Enter or closing the handwriting panel). What is currently not supported is live IME composition before it is committed. I'll look into whether composition support can be added cleanly.
Добавлено спустя 6 часов 7 минут:
yeyo:I found another problem. When jsplitter is nested with multiple layers of jsplitters and there are many jsplitter panels, even if these panels are all empty without code and the playback is stopped, the CPU will suddenly occupy a lot every few seconds or a period of time (observe the sudden jump in occupation in the task manager). When the default DUI has no jsplitter panels, the CPU basically remains at around 0% occupancy.
I tested a similar setup with many nested, empty JSplitter panels.
I can reproduce noticeable background CPU usage, but only when the panels are using D2D:
window.DrawMode = 1;
The reason is also clear from Process Explorer: each JSplitter panel running in D2D mode creates its own D2D/D3D device, and on my system each such device adds at least about 40 threads inside the NVIDIA user-mode graphics driver (nvwgf2umx.dll). Depending on the moment, the increase can be considerably higher. With many D2D panels (over 30), the process thread count therefore grows into the thousands, and the accumulated graphics-driver overhead becomes visible as background CPU usage which is hardly surprising for any application that already has over two thousand threads, even if they aren't particularly active and are simply waiting for work.
Anyway, in this case, it's driver activity, not the JSplitter's itself.
In a fresh GDI-only layout, where the panels never enable D2D, CPU usage remains effectively at 0% on my system. So in my tests the issue is specifically tied to having a large number of D2D panels.
BTW switching a panel back to:
window.DrawMode = 0;
does not destroy an already-created D2D device (cached). The device remains alive for the lifetime of the panel and is released only when the panel itself is destroyed, so the corresponding driver threads and resources remain as well.
So, if the graphics-driver overhead is a concern, I recommend enabling D2D only for panels that actually need it. There is normally no reason for every nested JSplitter panel or simple container panel to use DrawMode = 1. Panels that do not require D2D-specific rendering can remain in the default GDI mode.
What I do not know yet is whether your panels are actually using D2D. Could you please confirm:
  • approximately how many JSplitter panels are present;
  • whether they use window.DrawMode = 1
  • how high the CPU usage rises on your system;
  • and whether the same behavior occurs in a fresh layout where the panels have never enabled D2D.
If it also happens with panels that have only ever used GDI, then it is a different issue.
GDI (30 panels):
D2D (30 panels):
С нами: 14 лет
Сообщение #562 yeyo » 16.10.2026, 03:07
LUR:committed. I'll look into whether composition support can be added cleanly.
Looking forward to your modifications and improvements
LUR:If it also happens with panels that have only ever used GDI, then it is a different issue.
Thank you for your test. Yes, the same is true for GDI. I cleared all the code in all jsplitter panels (no other component panels were added), but there will still be a jump in CPU usage. I have a laptop with a 6700HQ CPU and a desktop computer with a 11600K CPU. Both have this problem, but the jump on the laptop is easier to see. Sometimes the jump will reach 5%+ usage. Of course, this is just an appearance. It would be best if the reason can be found.
yeyo
С нами: 4 года 2 месяца
Сообщение #563 LUR » 17.10.2026, 03:19
yeyo:Thank you for your test. Yes, the same is true for GDI. I cleared all the code in all jsplitter panels (no other component panels were added), but there will still be a jump in CPU usage. I have a laptop with a 6700HQ CPU and a desktop computer with a 11600K CPU. Both have this problem, but the jump on the laptop is easier to see. Sometimes the jump will reach 5%+ usage. Of course, this is just an appearance. It would be best if the reason can be found.
I could not reproduce this with GDI.
I have already investigated JSplitter's threading model, including its worker threads and thread pools, and with empty GDI panels there is simply no per-panel background activity that should periodically wake up and cause CPU spikes. In my tests, even with around 30 empty GDI JSplitter panels, the process keeps the normal thread set and CPU usage remains effectively at zero.
Because of that, the source of these spikes may be outside JSplitter itself — for example, in another component, the host application, or some interaction specific to the current configuration.
Also, when you say "a jump in CPU usage", please clarify exactly what you mean. Is there a constant elevated CPU load, or is it a short temporary spike that appears from time to time? If it is a spike, how often does it happen, how long does it last, and does it happen while the player is completely idle?
At this point I need a reproducible configuration to investigate further. Please provide the exact setup, including the list of installed components/plugins and the steps needed to reproduce the issue. Even better, if possible, provide a complete portable foobar2000 folder/archive containing the configuration, plugins, and the "empty panel" layout where the issue occurs.
The important part is that I need to know exactly how to reproduce the behavior. Without a reproducible setup or precise reproduction steps, there is currently nothing specific in JSplitter to trace further.
С нами: 14 лет
Сообщение #564 yeyo » 18.10.2026, 04:41
LUR:Also, when you say "a jump in CPU usage", please clarify exactly what you mean. Is there a constant elevated CPU load, or is it a short temporary spike that appears from time to time? If it is a spike, how often does it happen, how long does it last, and does it happen while the player is completely idle?
It is not a continuous high usage, but an irregular spike (a few seconds or tens of seconds), which occurs when the playback is stopped or no songs or media libraries are added at all. I attach a test.fth file (all the default jsplitter panel, in the new When only the jsplitter component is installed on the installed foobar2000, switch with the layout that comes with fb in View-Layout-Quick Setting (observe). This fth may be meaningless to you. If it cannot be reproduced, please ignore this problem.
Добавлено спустя 4 часа 28 минут:
Hi,@LUR
I found the reason. My laptop has i7-6700HQ + GTX960M dual graphics cards. I ran foobar2000 under the integrated graphics, and the CPU stabbing problem disappeared. Running on GTX960M can reproduce the CPU stabbing problem, so this problem should be my case.
Test.fth
yeyo
Сообщение #565 yeyo » 05.11.2026, 15:10
@LUR
The last time I reported on the problem of white background flickering at startup, I had the impression that you used the dark and light colors of foobar2000 for processing. The test found that this would cause another problem. When the window mode is set to "NoBorder", when the window is restored from minimization, the jsplitter panel will be filled with the background color, causing the panel to flicker. It is recommended not to perform any filling and make it transparent, which should avoid this problem, right?
Phenomenon video:
https://drive.google.com/file/d/1Scig6B1OTsGbKJVik1m1uIq5gBqx3BFm/view?usp=sharing
https://drive.google.com/file/d/1uF06BXbEKgxi9ECfSYOHx7EB_Z4m_U9M/view?usp=sharing
yeyo
Сообщение #566 LUR » 05.11.2026, 22:25
yeyo,
The startup background fill is only meant to hide the initial white flash before the first valid frame. It should not normally be involved in minimize/restore.
However, seeing the foobar2000 background color does not necessarily mean that this fill is the cause. JSplitter is also a window container and handles child-window positioning, layout and repainting, so several parts of the restore sequence can produce the same visible effect.
I’ve already had a repaint-related report where a seemingly small fix actually made the behavior worse in other cases, so I’d rather not change this path based on the visual symptom alone.
Making the panel transparent would not be a safe general fix either, as transparent child windows have their own repaint-order and flicker issues.
С нами: 14 лет
Сообщение #567 LUR » 06.11.2026, 06:53
Версия 4.4.0 [06.11.2026]
  • [НОВОЕ] Добавлен новый API визуализаций, построенный на переиспользуемых источниках аудиоданных и рендерерах. Для правильного и эффективного использования API настоятельно рекомендуется ознакомиться с документацией и входящими в комплект примерами.
  • [ИСПРАВЛЕНИЕ] Исправлены некорректные границы окна при повторном запуске foobar2000 в развёрнутом состоянии с включённым режимом NoBorder. Теперь окно точно вписывается в рабочую область монитора, не выходя за её края.
  • [ИСПРАВЛЕНИЕ] Зона захвата для изменения размеров окна в режиме NoBorder уменьшена до системных значений SM_CXFRAME/SM_CYFRAME с учётом DPI, без дополнительного отступа рамки (обычно 4 px при 96 DPI). Это упрощает доступ к элементам управления у краёв окна.
  • [ИСПРАВЛЕНИЕ] Обработка изменения размеров окна у его краёв в режиме NoBorder больше не мешает текущим действиям мышью, например перетаскиванию ползунка полосы прокрутки. Обработчик больше не перехватывает движение мыши, пока удерживается кнопка мыши или активен захват мыши.
  • [НОВОЕ] Добавлена поддержка ввода положения и размеров дочерних панелей в процентах в диалоге списка панелей и в режиме редактирования заголовков.
  • [ИСПРАВЛЕНИЕ] Исправлено несоответствие полос прокрутки для панелей, выходящих за пределы видимой области, текущей теме foobar2000.
  • [НОВОЕ] Добавлен доступ к отдельному окну Менеджера пакетов из главного меню foobar2000.
  • [ОБНОВЛЕНИЕ] Добавлена поддержка тёмной темы для всплывающих подсказок.
  • [НОВОЕ] Добавлено доступное только для чтения свойство window.HostWindowTitle, возвращающее заголовок ближайшего родительского контейнера с непустым заголовком.
  • [ОБНОВЛЕНИЕ] Расширен список альтернативных названий стран, распознаваемых utils.GetCountryFlag, и добавлена поддержка трёхбуквенных кодов стран ISO 3166-1 alpha-3. Поддерживаемые названия и коды приведены в обновлённом файле countries.json.
  • [НОВОЕ] Добавлен метод utils.TextBox для ввода многострочного текста.
  • [НОВОЕ] Добавлена поддержка ввода через IME с функциями обратного вызова on_ime_start, on_ime_update и on_ime_end.
  • [ИСПРАВЛЕНИЕ] Исправлены инициализация статистики воспроизведения и обработка изменений выражения форматирования заголовков, используемого для идентификации треков. Теперь изменение этого выражения очищает существующую статистику воспроизведения JSplitter при следующем запуске. Само по себе обновление компонента не сбрасывает накопленную статистику.
  • [ИСПРАВЛЕНИЕ] Изменения переменных окружения, передаваемые через WM_SETTINGCHANGE, больше не вызывают лишнее глобальное обновление цветов и шрифтов. Это устраняет сильное мерцание и повторные перерисовки в конфигурациях с большим количеством вложенных панелей JSplitter, не затрагивая обработку других изменений системных параметров.
  • [ОБНОВЛЕНИЕ] Движок JavaScript обновлён до SpiderMonkey 153.6.0esr.
  • [ОБНОВЛЕНИЕ] Движок редактора исходного кода обновлён до Scintilla 5.6.9.
С нами: 14 лет
Сообщение #568 yeyo » 10.11.2026, 08:40
LUR:The startup background fill is only meant to hide the initial white flash before the first valid frame. It should not normally be involved in minimize/restore.
I understand your concerns, but this will cause the background rendering to be abnormal when some panels that support pseudo-transparency are restored from minimization, such as: foo_vis_spectrum_analyzer component, please view the video:
https://drive.google.com/file/d/1CbulG4PKOyMpxjrAiyvoJ4S9bL1sIc1g/view?usp=sharing
Attached is the foo_vis_spectrum_analyzer configuration file for testing. Place it in the profile directory and load it in the configuration.
foorab-stereo-h.zip
yeyo
Сообщение #569 zjp_m » 16.11.2026, 11:11
I've run into a similar problem too , us foo_uie_jsplitter to remove the native window border. This causes three issues:
1. When restoring the window from the taskbar or system tray, a black background block is briefly visible during redraw.
2. Windows 11 Snap Layouts no longer works — dragging the window by its title bar to the screen edge does not trigger Snap Layouts.
3. The scale/restore animation when restoring from the taskbar or system tray has disappeared.
For comparison, removing the native border with foo_openhacks does not cause any of these issues.
Steps to reproduce:
1. Enable native border removal in foo_uie_jsplitter.
2. Minimize to taskbar/tray, then restore the window.
3. Observe the black redraw artifact and the missing restore animation.
4. Drag the window by its title bar to the screen edge and check whether Snap Layouts is triggered.
zjp_m
С нами: 7 дней 11 часов
Сообщение #570 LUR » 16.11.2026, 17:49
zjp_m:black background block is briefly visible during redraw
I wasn't able to reproduce this specific issue, but I’ve fixed the other things you specified, and those fixes will be included in the next release.
С нами: 14 лет
Сообщение #571 Marakobes » 17.11.2026, 10:50
почему у меня трафик идет через ВПН а через системный прокси - [9:52:04] Last.fm Similar Artists + User Charts + Recent Tracks: Access Denied - You cannot access this service? С тем же IP когда переключаюсь в режим ВПН все ок
Marakobes
С нами: 14 лет 3 месяца
Сообщение #572 Azaza » 17.11.2026, 18:16
Marakobes:почему у меня трафик идет через ВПН а через системный прокси - [9:52:04] Last.fm Similar Artists + User Charts + Recent Tracks: Access Denied - You cannot access this service? С тем же IP когда переключаюсь в режим ВПН все ок
1 вариант. В фубаре есть настройка прокси в File->Preferences->Networking. Поддерживается только http прокси. Она влияет не только на интернет-радио, как можно было бы подумать. Возможно, там выбрано "No proxy"
2 вариант. Возможно, программа для прокси настроена только на обход блокировок для сайтов, заблокированных в РФ. Однако, last.fm не заблокирован в РФ, он сам блокирует подключения из РФ.
С нами: 10 лет 2 месяца
Сообщение #573 Marakobes » 17.11.2026, 21:51
Все выды прокси там включал и порты - ну не идет через прокси и все тут, локации разные не только РФ
Marakobes
Сообщение #574 LUR » 20.11.2026, 02:23
Версия 4.4.1 [20.11.2026]
  • [ИСПРАВЛЕНО] Исправлена привязка окон к краям экрана и анимация сворачивания/восстановления в режиме NoBorder.
  • [ИСПРАВЛЕНО] Начиная с SpiderMonkey 153.6.0esr, WebAssembly требует соблюдения стандарта IEEE 754 при операциях с плавающей точкой. Для выполнения этого требования и предотвращения аварийных завершений во время работы JavaScript теперь отключаются флаги FTZ и DAZ в регистре MXCSR.
  • [ОБНОВЛЕНО] Добавлена поддержка URL-адресов file:///* для кнопки справки в следующих диалоговых окнах:
  • [ИСПРАВЛЕНО] Исправлена обработка многострочного текста приглашения в utils.TextBox.
  • [ИСПРАВЛЕНО] Исправлен неверный индекс цвета фона CUI в примерах Visualization API.
  • [ИСПРАВЛЕНО] Исправлена отрисовка градиентов в поддерживаемых визуализациях (Spectrum, PeakMeter и VUMeter).
  • [ОБНОВЛЕНО] Добавлено изменяемое на лету свойство Opacity для встроенных рендереров визуализаций. Для проверки нового свойства см. обновлённый пример Builtin - Interactive Showcase.js.
  • [ОБНОВЛЕНО] НЕСОВМЕСТИМОЕ ИЗМЕНЕНИЕ utils.LoadFont теперь возвращает непустой массив имён семейств шрифтов при успешной загрузке или null при ошибке. Добавлена поддержка коллекций шрифтов TTC/OTC.
  • [ОБНОВЛЕНО] Расширены возможности utils.CheckFont для проверки наличия шрифтов в режимах GDI и Direct2D.
  • [ИСПРАВЛЕНО] Устранены лишние перезагрузки скриптов, вызываемые сообщением WM_THEMECHANGED.
  • [ОБНОВЛЕНО] Движок JavaScript обновлён до SpiderMonkey 153.7.0esr.
С нами: 14 лет
Сообщение #575 LUR » Сегодня, 04:54
С нами: 14 лет
