Dr.Death's foobar2000 Pack v0.9.4f
Сообщение #1 Dr.Death » 03.05.2006, 13:13
Cборка версии 0.9.4 Final
Dr.Death's foobar2000 Pack v0.9.4f (~3.1 мб)
Dr.Death's foobar2000 Pack Lite v0.9.4f (~2.2 мб) без кодеков и утилит
Тема на моем форуме там же change log
Active components:
Core.dll vv0.9.4 [] - foobar2000 core
foo_ac3.dll v0.7 [23 March 2006] - AC3 decoder
foo_albumlist_autoupdate.dll v0.1 [25 August 2006] - Albumlist autoupdate
foo_bitcompare.dll v1.1 [04 August 2006] - Binary Comparator
foo_cdda.dll v2.1.1 [23 September 2006] - CD Audio Decoder
foo_converter.dll v1.0.1 [23 September 2006] - Converter
foo_cuesheet_creator.dll v0.4.3a [04 May 2006] - Cuesheet Creator
foo_cwb_hooks.dll v1.0.11 [Sep 22 2006 - 17:01:48] [23 September 2006] - cwbowron's title format hooks
foo_dbsearch.dll v1.4 beta 3 [04 June 2006] - Database search
foo_dsp_std.dll v1.0 [23 September 2006] - Standard DSP array
foo_freedb2.dll v0.5.2a [29 August 2006] - freedb Tagger
foo_input_monkey.dll v2.1.1 [04 August 2006] - Monkey's Audio decoder
foo_input_std.dll v1.1.0 [23 September 2006] - FLAC decoder
foo_input_std.dll v1.1 [23 September 2006] - WMA Decoder
foo_input_std.dll v1.0 [23 September 2006] - Standard Input Array
foo_lock_ex.dll v1.0 [19 May 2006] - Pause on Lock (extended)
foo_masstag.dll v1.6 [23 September 2006] - Masstagger
foo_navigator.dll v0.2 [13 June 2006] - Navigator
foo_out_ks.dll v1.2.2 [04 August 2006] - Kernel Streaming Output
foo_playcount.dll v1.3.2 [16 September 2006] - Playback Statistics
foo_rgscan.dll v2.0.2 [23 September 2006] - ReplayGain Scanner
foo_ui_columns.dll v0.1.3 beta 1v6 TEST [08 September 2006] - Columns UI
foo_uie_albumart.dll v0.2.4.1 [20 September 2006] - Album Art Panel
foo_uie_albumlist.dll v0.2.1 beta 4 [28 April 2006] - Album list panel
foo_uie_bookmarks.dll v0.0.2f [04 August 2006] - Bookmarks
foo_uie_console.dll v0.2 [28 April 2006] - Console panel
foo_uie_single_column_playlist.dll v0.3.2 beta [Sep 20 2006 - 06:11:29] [20 September 2006] - Single Column Playlist Display
foo_uie_tabs.dll v0.2.4 [15 September 2006] - Tabbed panel modified
foo_uie_trackinfo.dll v0.8 [03 May 2006] - Track info panel
foo_unpack.dll v1.1 [23 September 2006] - RAR reader
foo_unpack.dll v1.0 [23 September 2006] - ZIP/GZIP reader
foo_utils.dll v0.5.8 [09 May 2006] - Playlist tools
foo_verifier.dll v1.0.1 [29 August 2006] - File Integrity Verifier
foo_version.dll v0.3 [18 July 2006] - Components versions viewer
Последний раз редактировалось Dr.Death 24.09.2006, 17:05, всего редактировалось 1 раз.
Dr.Death M
С нами: 20 лет 5 месяцев
Сообщение #2 FireBurner » 07.05.2006, 21:53
Самая лучшая сборка! Без ненужной визуализации и ещё кучи всякой дряни. Respect!
FireBurner M
Сообщение #3 Dr.Death » 08.05.2006, 11:39
велкум  :-[
Dr.Death M
Сообщение #4 Anatoly » 08.05.2006, 13:49
Прикольная! ;) Пасибо! уже 3й буду пользоваться! :))
Anatoly M
Сообщение #5 Sars » 10.05.2006, 23:47
Здравствйте Dr.Death.Спасибо за отличную сборку.Всё работает.Только кнопки плохо отображаются.Не пинайте меня ногами не нашёл я кнопку -Customise- на Foobare.У меня её просто нет.Поможите чайнику объясните.Может чего не доделал?С уважением и благолепием.
:o
Sars
Сообщение #6 Sp1ke » 11.05.2006, 06:52
2Sars
правой кнопкой мыши щелкни по кнопкам фубара
Sp1ke M
Основатель
Сообщение #7 Dr.Death » 11.05.2006, 07:38
ну вот, пока ходил все объяснили 8)
а вобще в readme.txt написано:
[glow=red,2,300]1. Правой крысой на кнопках -> Customise... -> Tools -> Load From File... -> "Dr.Death Button Pack.fcb" для нормального отображения кнопок
думаю вполне доступным языком написано 8\
Dr.Death M
Сообщение #8 Sars » 11.05.2006, 12:41
:-) пасиба.Простите тупоголового.Ещё раз благодарю за классную сборку.
Sars
Сообщение #9 RodionD » 12.05.2006, 23:13
А почему в последней сборке, я не могу добавить AlbumList Panel? Ее просто нету в списке доступных для добавления, хотя в настройках "Media Library" есть!
RodionD
Сообщение #10 Dr.Death » 13.05.2006, 13:04
у меня нет 8)
а если сам добавлял то в layout и добавляй ее
Dr.Death M
Сообщение #11 RodionD » 13.05.2006, 19:39
Так в том то и дело, что нет ее в списке возможных к добавлению!
PS: Версия DLL-ки foo_uie_albumlist.dll - 0.2.1 beta 2
RodionD
Сообщение #12 Dr.Death » 13.05.2006, 20:26
ну я хз, не пользуюсь и не интересуюсь, скорей всего надо что то обновить 8)
Dr.Death M
Сообщение #13 RodionD » 14.05.2006, 02:02
Да, помогла новая версия DLL-ки! Еще один вопрос: при закрытии foobar-а каждый раз выскакивает окошко со следующим текстом: "metadb_handle leaks: 2 object", цифирка каждый раз разная. Это что? И как убрать?
RodionD
Сообщение #14 Mishail » 14.05.2006, 02:30
2RodionD
Пока никак. Это бага в foo_uie_trackinfo.
Сообщение #15 terrogen » 14.05.2006, 10:23
2RodionD
А я просто поставил предыдущую версию foo_uie_trackinfo, предварительно скопировав его настройки, так как они слетают после отката.
terrogen M
Сообщение #16 DruiD » 14.05.2006, 11:23
2Mishail
2terrogen
Товарищи, эту багу уже давно поправили. Перекачайте еще раз. Он забыл версию увеличить как была 0.8 так и осталась :)
DruiD M
Сообщение #17 Mishail » 14.05.2006, 12:24
Кроме "косяк автора" и сказать-то нечего. Сейчас перекачаю. Спасибо за инфу
Сообщение #18 terrogen » 14.05.2006, 16:30
2DruiD
вах, дорогой, спасибо тебе :)
terrogen M
Сообщение #19 Dr.Death » 14.05.2006, 17:08
2terrogen ага, вах 8) обновил, нет косяков 8)
и главно размер один в один, я поэтому думал, что без изменений 8)[br][size=1]: 14 Мая 2006, 18:07[/size]и ваще брысь все отсюда, развели тут базар 8))
Dr.Death M
Сообщение #20 jamiro » 18.05.2006, 20:25
я раньше пользовался како-то старой сборкой спайка. все мне нравилось, но она обыла 0.8.х. новой нормальной пока не нашел. но сейчас понравилась и эта. но в старой для обозначения того, что альбом является сборником к каждому файлу сборника дописывался тег ALBUM ARTIST или PERFORMER  в который можно было заносить имя создателя сборника или названия сборника. музыки много и многое на дисках(т.е. уже не изменить).
вопрос: что и как мне подправить в скриптах конфига, чтобы при наличии этих тэгов разметка изменялась на соответствующую для сборника(в title  выводился %artist% - %title%, в первой строке альбома вместо Various Artist, содержимое тэгов ALBUM ARTIST или PERFORMER)?
или возможно в следующей редакции pack'a добавить такую функциональность.
jamiro M
