foobar2000 v1.6.6
Сообщение #1 VEG » 16.04.2021, 17:42
Вышла финальная версия foobar2000 v1.6.6! Предыдущая версия: foobar2000 v1.6.5. Версия для Windows XP: foobar2000 v1.5.
  • Made Advanced Preferences searchable.
  • Added support for attaching pictures to Matroska files; fixed Matroska tag editing bugs.
  • More accurate reporting of Matroska bitrate (actual content is probed if needed).
  • Added itunesadvisory tag support for M4A.
  • Updated embedded cuesheet handling code.
  • Replaced PPHS resampler with much faster libretro resampler.
  • Added support for internet radio album art.
  • Converter: Encoded FLAC files are now updated with proper FLAC seektables, if FLAC.exe doesn't write them by itself.
  • Converter: Workarounds for clashes when writing to a Media Library indexed folder.
  • Converter: Added built-in profile for exhale AAC encoder.
  • Converter: Fixed some warning prompts not being possible to permanently disable.
  • Fixed slightly inaccurate bitrate reporting for Musepack and WavPack. Tags are now excluded from file size used to calculate the bitrate.
  • Now compiled with Visual Studio 2019 (was 2017 before).
  • Album art related regressions fixed. (beta 2)
  • Worked around 7-zip reading crash. (beta 2)
  • Fixed missing no-artwork pic in some scenarios. (beta 3)
  • Fixed slower playlist & library search regression from earlier betas. (beta 4)
  • Fixed failure to read some rare MP4/M4A files. (beta 5)
  • Converter: Added a toggle for FLAC seektable fix. (beta 5)
  • Fixed Default UI playlist rendering glitches with millions of items. (beta 6)
  • Fixed decoding of 7-channel FLAC files. (beta 7)
  • Made FLAC channel mask not cleared with 'remove tags'. (beta 7)
  • Improved compatibility with badly configured HLS radio servers. (beta 7)
  • Fixed odd samplerate autoresampling regression from earlier betas. (beta 8)
Автор темы, Администратор
С нами: 14 лет
Сообщение #2 kolobok15 » 16.04.2021, 18:36
Давно пора! :razz:
kolobok15
С нами: 13 лет 6 месяцев
Сообщение #3 Гармонист » 18.04.2021, 20:15
Есть вероятность увеличения скорости работы из-за перехода на новый компилятор.
Гармонист
Сообщение #4 VEG » 20.04.2021, 12:06
beta 2
С нами: 14 лет
Сообщение #5 VEG » 27.04.2021, 09:01
beta 3 и beta 4
С нами: 14 лет
Сообщение #6 Гармонист » 29.04.2021, 11:41
Ни в коем случае не ставьте версию 1.66 beta 6 ==> 666
Гармонист
Сообщение #7 VEG » 04.05.2021, 12:07
beta 5
С нами: 14 лет
Сообщение #8 VEG » 05.05.2021, 12:10
beta 6
С нами: 14 лет
Сообщение #9 SergPuh.68 » 05.05.2021, 15:25
Ну прям не знаю,скачивать или нет :wink:
С нами: 7 лет 3 месяца
Сообщение #10 str » 08.05.2021, 17:51
Миллион треков?
str M
Сообщение #11 VEG » 11.05.2021, 01:18
beta 7
С нами: 14 лет
Сообщение #12 VEG » 12.05.2021, 17:59
beta 8
С нами: 14 лет
Сообщение #13 LUR » 18.05.2021, 02:54
foobar2000 v1.6.6 final
Сообщение #14 VEG » 18.05.2021, 10:36
Я уж думал до десятка бет дойдёт =) Давно не было такого количества бет для одного релиза.
С нами: 14 лет
Сообщение #15 Vittorio » 19.05.2021, 13:34
"Added support for internet radio album art." - кто-нибудь пробовал? у меня не получилось...
Vittorio
С нами: 10 лет 7 месяцев
Сообщение #16 Azaza » 19.05.2021, 22:10
Vittorio:"Added support for internet radio album art." - кто-нибудь пробовал? у меня не получилось...
Имеется в виду, что теперь для радиопотоков, передающих обложку, плеер её отображает. Пример потока с обложками - https://stream.radioparadise.com/aac-320
Сообщение #17 SergPuh.68 » 20.05.2021, 08:25
У меня тоже не отображается,может нужно какие то настройки дополнительные сделать?
Сообщение #18 Azaza » 20.05.2021, 08:44
В Properties не отображается, да. Отображается в Album art viewer, в DUI.
Вернуться в Новости плеера
