- Playback:
- Added an option to toggle additional decoding (DTS, HDCD, etc) during playback, so you can play DTS-WAV without decoding DTS.
 - Changed how DSP settings are applied when playing through a high-latency output such as UPnP.
 - WASAPI exclusive channel mask negotiation logic update - 5.1-side could be preferred over 7.1, causing unwanted channel remapping.
 - Fixed a bug that caused current track restart in certain scenarios, such as rapidly changing playback settings.
 - Fixed a bug causing audio glitching near the end of last song with WASAPI exclusive.
 - Rewritten full file buffer feature, no longer blocks until whole file has been read. Large FLAC files for an example should now open with no delay.
 - User interface:
- Fullscreen size of visualisations is no longer stored as last window size (2.0 regression).
 - Fixed playlist layout infinite update loop with column auto sizing and album art.
 - Fixed bad handling of preferences page creation errors (wrong message, broken dark mode).
 - ReFacets sorting changed to match playlist & album list sorting.
 - Made not flash main window if started with /hide switch.
 - Rewrote external album art lookup code, wildcard lookup now works where it didn't before.
 - Renamed "Notification Area" to "System Tray" everywhere.
 - Fixed dragging of WebP images to Properties dialog artwork tab.
 - Fixed seekbar & volume bar flickering in Default UI.
 - Forcefully suppressed dark mode if High Contrast is active.
 - Fixed some rendering glitches with big primary font selected.
 - Fixed first run dialog text truncation at 175% text size.
 - Default UI: Fixed toolbar font getting reverted to system default in response to certain events, such as system theme change.
 - Default UI: Fixed media library & playlist search edit boxes being too small if a large font is selected.
 - Properties: Fixed misbehavior of "Clear ReplayGain information" if the dialog was opened for just one track.
 - Various dark mode refinements.
 - Various screen reader accessibility issues addressed.
 - Various keyboard navigation glitches fixed.
 - Converter:
- Fixed bad encoding of AIFF 8-bit (unsigned instead of signed).
 - Added built-in profile for TAK.
 - Added built-in profile for Monkey's Audio.
 - Restored old behavior with .bat files, using full paths to start.
 - Internet radio & networking:
- Added Internet Radio Search feature, using radio-browser.
 - Rewritten HLS radio playback.
 - Improved FTP/HTTP playback & browsing, fewer connections used.
 - Lots of FTP issues fixed. Encrypted FTP now works properly.
 - Fixed specific cases of HTTP redirects being incorrectly handled.
 - Archive reading:
- Fixed non-working extraction of .RSN (renamed .RAR).
 - Updated RAR unpacker code to the latest RAR library version.
 - Updated zlib to v1.3.
 - Fixed stack overflow with specific archive files in indexed music folders.
 - Codec updates:
- Fixed incorrect handling of certain rare Monkey's Audio configurations.
 - Fixed missing decode postprocessor (DTS/HDCD etc) for TAK.
 - Fixed wrong reported length of certain RF64 WAV files.
 - Made possible to play Vorbis muxed into MP4.
 - Added support for tagging Wave64 & RF64 formats.
 - Report LC-AAC codec long name as just "AAC".
 - Fixed missing HE-AAC delay compensation, breaking gapless playback of HE-AAC encoded with modern encoders.
 - Made possible to read & write itunesalbumid & itunesartistid tags in M4A/MP4.
 - Implemented reading of multiplexed Ogg files.
 - Fixed bad handling of undefined-length chunks in WAV files.
 - Made MP3 VBRI delay reported and skipped correctly. Note that VBRI files are still not gapless.
 - Fixed missing "encoding" info field for AC3.
 - Fixed DTS codec info for DTS in Matroska.
 - Made TAK MD5 checksums read without TAK decoder component, allowing audio integrity verification.
 - Made FLAC seektable tool also rewrite oversized seektables.
 - FLAC decoder: log premature EOF, mark partially encoded files as bad even if they don't appear corrupted otherwise.
 - Added standard %codec_long% field to properly display detailed names of all codecs.
 - Improved reporting of AAC & DTS codec/profile info.
 - Fix for "DTS 96/24", made bit depth reported as 24-bit.
 - Made possible to decode float16 & float24 WAVs again.
 - Made possible to read ReplayGain info from Musepack APE tags (normally it's supposed to be in Musepack headers).
 - Updated libopus to v1.4
 - Updated Monkey's Audio to 10.30.
 - Other:
- Fixed bug in Media Library preventing previously-unplayable files from being reindexed after installation of new decoders (2.0 regression).
 - Improved recovery from corrupted configuration files.
 - Suppressed unnecessary playlist rewrite on autoplaylist startup.
 - Fixed loss of autoplaylist content order when upgrading from v1.x.
 - Made autoplaylist sort logic work more consistently with v1.x, that is, sort by just date/album/etc implicitly applies default sort criteria to date/album/etc groups.
 - Made search query GREATER/LESS/EQUAL treat numbers as floating-point rather than integer.
 - Crash log writer added timestamps to recent events.
