foobar2000 v2.1
Сообщение #1 VEG » 10.05.2023, 18:53
Вышел foobar2000 v2.1! Предыдущая версия: foobar2000 v2.0.
  • Playback:
    • Added an option to toggle additional decoding (DTS, HDCD, etc) during playback, so you can play DTS-WAV without decoding DTS.
    • Changed how DSP settings are applied when playing through a high-latency output such as UPnP.
    • WASAPI exclusive channel mask negotiation logic update - 5.1-side could be preferred over 7.1, causing unwanted channel remapping.
    • Fixed a bug that caused current track restart in certain scenarios, such as rapidly changing playback settings.
    • Fixed a bug causing audio glitching near the end of last song with WASAPI exclusive.
    • Rewritten full file buffer feature, no longer blocks until whole file has been read. Large FLAC files for an example should now open with no delay.
  • User interface:
    • Fullscreen size of visualisations is no longer stored as last window size (2.0 regression).
    • Fixed playlist layout infinite update loop with column auto sizing and album art.
    • Fixed bad handling of preferences page creation errors (wrong message, broken dark mode).
    • ReFacets sorting changed to match playlist & album list sorting.
    • Made not flash main window if started with /hide switch.
    • Rewrote external album art lookup code, wildcard lookup now works where it didn't before.
    • Renamed "Notification Area" to "System Tray" everywhere.
    • Fixed dragging of WebP images to Properties dialog artwork tab.
    • Fixed seekbar & volume bar flickering in Default UI.
    • Forcefully suppressed dark mode if High Contrast is active.
    • Fixed some rendering glitches with big primary font selected.
    • Fixed first run dialog text truncation at 175% text size.
    • Default UI: Fixed toolbar font getting reverted to system default in response to certain events, such as system theme change.
    • Default UI: Fixed media library & playlist search edit boxes being too small if a large font is selected.
    • Properties: Fixed misbehavior of "Clear ReplayGain information" if the dialog was opened for just one track.
    • Various dark mode refinements.
    • Various screen reader accessibility issues addressed.
    • Various keyboard navigation glitches fixed.
  • Converter:
    • Fixed bad encoding of AIFF 8-bit (unsigned instead of signed).
    • Added built-in profile for TAK.
    • Added built-in profile for Monkey's Audio.
    • Restored old behavior with .bat files, using full paths to start.
  • Internet radio & networking:
    • Added Internet Radio Search feature, using radio-browser.
    • Rewritten HLS radio playback.
    • Improved FTP/HTTP playback & browsing, fewer connections used.
    • Lots of FTP issues fixed. Encrypted FTP now works properly.
    • Fixed specific cases of HTTP redirects being incorrectly handled.
  • Archive reading:
    • Fixed non-working extraction of .RSN (renamed .RAR).
    • Updated RAR unpacker code to the latest RAR library version.
    • Updated zlib to v1.3.
    • Fixed stack overflow with specific archive files in indexed music folders.
  • Codec updates:
    • Fixed incorrect handling of certain rare Monkey's Audio configurations.
    • Fixed missing decode postprocessor (DTS/HDCD etc) for TAK.
    • Fixed wrong reported length of certain RF64 WAV files.
    • Made possible to play Vorbis muxed into MP4.
    • Added support for tagging Wave64 & RF64 formats.
    • Report LC-AAC codec long name as just "AAC".
    • Fixed missing HE-AAC delay compensation, breaking gapless playback of HE-AAC encoded with modern encoders.
    • Made possible to read & write itunesalbumid & itunesartistid tags in M4A/MP4.
    • Implemented reading of multiplexed Ogg files.
    • Fixed bad handling of undefined-length chunks in WAV files.
    • Made MP3 VBRI delay reported and skipped correctly. Note that VBRI files are still not gapless.
    • Fixed missing "encoding" info field for AC3.
    • Fixed DTS codec info for DTS in Matroska.
    • Made TAK MD5 checksums read without TAK decoder component, allowing audio integrity verification.
    • Made FLAC seektable tool also rewrite oversized seektables.
    • FLAC decoder: log premature EOF, mark partially encoded files as bad even if they don't appear corrupted otherwise.
    • Added standard %codec_long% field to properly display detailed names of all codecs.
    • Improved reporting of AAC & DTS codec/profile info.
    • Fix for "DTS 96/24", made bit depth reported as 24-bit.
    • Made possible to decode float16 & float24 WAVs again.
    • Made possible to read ReplayGain info from Musepack APE tags (normally it's supposed to be in Musepack headers).
    • Updated libopus to v1.4
    • Updated Monkey's Audio to 10.30.
  • Other:
    • Fixed bug in Media Library preventing previously-unplayable files from being reindexed after installation of new decoders (2.0 regression).
    • Improved recovery from corrupted configuration files.
    • Suppressed unnecessary playlist rewrite on autoplaylist startup.
    • Fixed loss of autoplaylist content order when upgrading from v1.x.
    • Made autoplaylist sort logic work more consistently with v1.x, that is, sort by just date/album/etc implicitly applies default sort criteria to date/album/etc groups.
    • Made search query GREATER/LESS/EQUAL treat numbers as floating-point rather than integer.
    • Crash log writer added timestamps to recent events.
VEG M Онлайн
Автор темы, Администратор
С нами: 14 лет 5 месяцев
Сообщение #21 VEG » 25.08.2023, 09:12
2023-08-24
  • Fixed wrong zlib DLL bundled, causing 32-bit version to crash.
VEG M Онлайн
Сообщение #22 VEG » 29.08.2023, 15:31
2023-08-28
  • Stability fixes.
  • Fixed media library memory leak regression from a month ago.
VEG M Онлайн
Сообщение #23 VEG » 14.09.2023, 16:09
2023-09-13
  • ReFacets filtering performance improved.
  • Installer update.
VEG M Онлайн
Сообщение #24 VEG » 15.09.2023, 15:04
2023-09-14
  • Various performance optimizations.
VEG M Онлайн
Сообщение #25 VEG » 23.09.2023, 16:41
2023-09-22
  • Playlist search regression fix, return key wasn't handled.
  • Less forced info reloading on played tracks.
VEG M Онлайн
Сообщение #26 VEG » 29.09.2023, 16:41
2023-09-28
  • Improved corrupted profile recovery (radio bookmarks database).
  • Updated Monkey's Audio to 10.23.
  • Fixed missing component version info in crash reports.
VEG M Онлайн
Сообщение #27 VEG » 11.10.2023, 18:43
2023-10-11
  • ReFacets accessibility issues fixed.
VEG M Онлайн
Сообщение #28 VEG » 13.10.2023, 16:55
2023-10-13
  • Improved behavior if multiple components have the same name. In recent 2.1 builds, neither would get loaded, leading in some cases to completely non-working foobar2000 install.
  • Fixed bug in Media Library preventing previously-unplayable files from being reindexed after installation of new decoders.
VEG M Онлайн
Сообщение #29 VEG » 30.10.2023, 17:57
2023-10-30
VEG M Онлайн
Сообщение #30 VEG » 07.11.2023, 22:26
2023-11-07
  • Fixed an embarrassing RAR regression that caused content of RAR archives to be extracted to the current directory while reading, failing to read archive if not possible to extract.
  • ReFacets fixed unwanted scrolling on focus change.
  • Fixed incorrect handling of HTTP redirects with spaces in path.
VEG M Онлайн
Сообщение #31 VEG » 08.11.2023, 22:55
2023-11-08
  • Fixed PCM-in-MP4 decoding error regression.
  • Fixed inverted sort indicators in Internet Radio Search.
  • Additional debug logging for specific app-fails-to-start issue.
VEG M Онлайн
Сообщение #32 VEG » 10.11.2023, 00:49
2023-11-09
  • Fixed bad behavior when rewinding MP4 DASH files.
  • Fixed HTTP redirect handling regression which broke some radio stations.
  • Converter: Changed FDK AAC link to rarewares.
  • Updated exclusive output channel remapping logic again.
VEG M Онлайн
Сообщение #33 ManikManik2011 » 20.11.2023, 13:43
С такой скоростью выхода новых версий рационально ли каждый раз обновлять его или дождаться релиза 2.1? :help:
ManikManik2011 M
С нами: 3 года 5 месяцев
Сообщение #34 VEG » 23.11.2023, 11:09
Это уже тебе решать, хочешь ли ты бету с самыми новыми фичами, или стабильную версию.
VEG M Онлайн
Сообщение #35 Azaza » 23.11.2023, 22:39
Ну, вообще, в бетах 2.1 меньше багов, чем в стабильной 2.0.
С нами: 10 лет 1 месяц
Сообщение #36 VEG » 27.11.2023, 22:59
2023-11-22
  • Bitcompare: "dBTP" renamed to "dBFS", as there's no true peak math involved.
  • Monkey's Audio updated to 10.27.
  • ReFacets sorting behavior updated again.
  • Internet Radio keyboard accessibility fixes.
2023-11-27
  • Fixed missing HE-AAC delay compensation, breaking gapless playback of HE-AAC.
  • Monkey's Audio updated to 10.28.
  • Internal performance optimizations.
VEG M Онлайн
Сообщение #37 VEG » 06.12.2023, 17:54
2023-12-06
  • Last HE-AAC fix fixed Apple/FDK but broke Nero AAC gapless. This has now been corrected.
  • Fullscreen size of visualisations is no longer stored as last window size (was 2.0 regression);
VEG M Онлайн
Сообщение #38 VEG » 11.12.2023, 23:35
2023-12-11
  • Fixed internet radio search failing to play stations where referenced M3U playlist links multiple alternate streams.
  • Internet radio search accessibility fixes.
  • Ignore malformed radio stream title returned by specific streams.
  • Fixed various table views no longer recognizing keyboard shortcuts (F2 etc) since the introduction of dark mode support.
  • Made possible to play plain MP4 (not DASH) files from HTTP servers that don't report content-length.
VEG M Онлайн
Сообщение #39 VEG » 16.12.2023, 20:01
2023-12-15
  • Converter: Fixed bad encoding of AIFF 8-bit (unsigned instead of signed).
  • Fixed missing decode postprocessor (DSD/HDCD etc) for TAK.
VEG M Онлайн
Сообщение #40 MrGrey » 18.12.2023, 18:28
2023-12-18
foobar2000 v2.1 final has been released
